Cotangent function integration problem
The integration problem involves evaluating the expression for cotangent and its relationship to tangent at specific limits. Substituting values directly into the antiderivative yields valid results for cotangent, while using tangent leads to undefined behavior at certain points, specifically at pi/2. The discussion highlights that cotangent is defined at pi/2, while tangent is not, necessitating the use of limits when dealing with tangent. This discrepancy explains the 'weird' results encountered when substituting into the tangent expression. Understanding the domain restrictions of these functions is crucial for correctly evaluating integrals involving them.
Benny
I was doing an integration question earlier on and I came across something that I would like to be cleared up. The question basically boiled down to:
<br /> - \left[ {\cot \left( \theta \right) + \theta } \right]_{\frac{\pi }{6}}^{\frac{\pi }{2}} = - \left[ {\frac{{\cos \left( \theta \right)}}{{\sin \left( \theta \right)}} + \theta } \right]_{\frac{\pi }{6}}^{\frac{\pi }{2}} <br />
Now if I just substitute the relevant values into the antiderivative it works out fine. However if I write the following I end up getting a 'weird' (I do not
know the right words to describe it :biggrin: ) answer(something involving 1/infinity).
<br /> - \left[ {\cot \left( \theta \right) + \theta } \right]_{\frac{\pi }{6}}^{\frac{\pi }{2}} = - \left[ {\frac{1}{{\tan \left( \theta \right)}} + \theta } \right]_{\frac{\pi }{6}}^{\frac{\pi }{2}} <br />
Can someone explain to me why this occurs? I can understand that when certain values are substituted in, 'weird' numbers appear but I cannot understand why the question works/does not work, depending on which way an expression is written(I am referring to the cotangent function), even though it is just the same thing. Any help would be good. I hope I was not unclear. :biggrin:
That's because \frac{\pi}{2} [/tex] is the domain of cotangent (cot pi/2=0) and not in the domain of tangent (tan pi/2 does not exist).Taking this int consideration,at best u can do is set a limit for the 1/tangent.But again,why do that,when pi/2 is clearly in the domain on cotangent and the result works out fine?<br /> <br /> Daniel.
Thanks for clearing that up for me.
