Coulombs Law and Electric Charges
A charge of 7.00 mC is positioned at each corner of a square with sides measuring 0.80 m, and the discussion revolves around calculating the force on each charge. The problem presents challenges in determining the net force, particularly for one of the charges. Participants suggest leveraging the symmetry of the square to simplify the calculations, noting that the forces acting on each charge are equivalent in direction and magnitude. Understanding the geometry, such as the properties of an equilateral triangle, is highlighted as beneficial for solving the problem. Overall, the conversation emphasizes the importance of symmetry in electric charge interactions.
polarized
Likewise, this similar problem also has me stumped
A charge of 7.00 mC is placed at each corner of a square 0.80 m on a side. Determine the magnitude of the force on each charge.
Any help would be greatly appreciated!
OMG,this is funny... :smile: :smile: :smile: :smile: :smile:
Do you know what an equilateral triangle is?
Daniel.
I'm insulted.
Yes, I know what an equilateral triangle is. It has three sides of equal length, and all three angles are 60 degrees. As I stated, I found the net force on two of the points, but Q(1) is giving me issues. Obviously the way I'm trying is wrong, so I'd like help, thank you.
You deleted the problem.Anyway,since you know what a equilateral triangle is,u might use the fact that the problem is symmetric (actually the geometry) so the directions of the forces are equivalent.If the charges were all 3 equal,then the problem would b solved if u managed to find the net foce acting only on one angle,since on the other two is practically the same,in modulus,of course.
Daniel.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
