Covariant Uncertaintly Principle
jfy4
Covariant Uncertainty Principle
Hi,
is it possible to write the uncertainty principle as a dot product like:
\eta^{\alpha\beta}\Delta x_{\alpha}\Delta p_{\beta}\geq\hbar
or even to generalize it as
g^{\alpha\beta}\Delta x_{\alpha}\Delta p_{\beta}\geq\hbar
That's not so clear. What's meant by \Delta x and \Delta p here? Note that it is not trivial to define, e.g., position operators for massless particles with spin (e.g., there's no position operator for photons in the strict sense).
You find a good review on the implications of the uncertainty relations in the context of relativistic quantum theory in the beginning of Landau-Lifgarbages vol. IV. This goes back to a famous paper by Bohr.
@vanhees71: I'm curious why there's no position operator for photons in the strict sense? Could you explain?
jfy4 said:
Hi,
Yes, provided that you work in an extended Hilbert space as in
http://xxx.lanl.gov/abs/0811.1905 [Int. J. Quantum Inf. 7 (2009) 595-602]
But you are missing a factor of D/2=2 for D=4 spacetime dimensions. The correct relation for D=4 is
\eta^{\alpha\beta}\Delta x_{\alpha}\Delta p_{\beta}\geq 2\hbar
Yes (with the same correction).
That's curious. When I first wrote it out, I had the 2, but then I thought with the lorentzian signature that the temporal component would subtract one of the the \hbar/2s.
Would it not contract as follows?
\eta^{\alpha\beta}\Delta x_{\alpha}\Delta p_{\beta}=-\Delta t\Delta E+\Delta x\Delta p_x +\Delta y\Delta p_y +\Delta z\Delta p_z\geq -\frac{\hbar}{2}+\frac{\hbar}{2}+\frac{\hbar}{2}+\frac{\hbar}{2}=\hbar
No!
You should start from the canonical uncontracted uncertainty relation
\Delta x^{\alpha}\Delta p_{\beta}=\frac{\hbar}{2} g^{\alpha}_{\beta}
and observe that, in any spacetime,
g^{\alpha}_{\beta}=\delta^{\alpha}_{\beta}
Demystifier said:
No!
Interesting.
Where did you find that/How did you know to use that equation (inequality?)? Else, what's wrong with my contraction above?
jfy4 said:
Interesting.
Well, the uncertainty relation above is a consequence of
1) The canonical commutation relations
[x^{\alpha},p_{\beta}]=-i\hbar g^{\alpha}_{\beta}
which is Eq. (3) in
and
2) The fact that the canonical momentum associated with x^{\alpha} is p_{\alpha} (not p^{\alpha} as one might naively think).
Your contraction is wrong because it starts from a wrong uncontracted relation. This is related to 2) above.
kof9595995 said:
Thanks, though I can't really understand the proof.
In a nutshell, the essence of the argument is the following.
A position operator for a spin s particle needs a 2s+1 dimensional spin space.
(Why this is necessary is the most difficult part of the argument.)
This is the case for massive particles. But massless particles only have a 1- or 2-dimensional spin space, depending on whether or not they are chiral.
Photons are not chiral and have spin 1, hence they have only 2 instead of the 3 spin components needed. The missing component would be ''longitudinal'' photons, which do not exist (and cannot for a massless particle).
I'm curious what's the physical consequence, does it simply mean we can never measure (or even define?) the position of a photon?
Not according to the textbook view of measurements. But there are more approximate notions of measurable position, defined in terms of POVMs rather than operators.
http://en.wikipedia.org/wiki/POVM
which is Eq. (3) in
and
Thanks,
I'll spend some time pondering it over.
