Create a method to measure a varying voltage from a power line
The discussion focuses on creating a method to measure varying voltage from a power line using a wire loop with adjustable diameter. The concept involves changing the loop's diameter to alter the magnetic flux, which generates a current in the wire. Participants emphasize the need to measure the current rather than the electric field to determine the voltage potential with respect to ground. The conversation highlights the importance of understanding the relationship between magnetic fields and induced currents in this context.
  • Understanding of electromagnetic induction principles
  • Familiarity with current measurement techniques
  • Knowledge of wire loop configurations and their effects on magnetic flux
  • Basic concepts of electric fields and their relationship to current flow
  • Research methods for measuring induced current in wire loops
  • Explore the principles of electromagnetic induction in detail
  • Learn about different configurations of wire loops and their impact on flux
  • Investigate tools for measuring voltage and current in electrical circuits
Electrical engineers, hobbyists working on power line measurements, and anyone interested in electromagnetic induction and current measurement techniques.
estudent1371
Describe a method to measure the current in an electric power line given (i) some wire that you can bend into any size and shape you want, and (ii) some method for measuring the frequency and amplitude of a voltage that varies periodically with time.Make sure to provide enough information for somebody else to reproduce your method.
Key information includes the following:
(a) The basic concept of your measurement: what you will do, what you will measure, and why that measurement will tell you the current in the power line.
(b) Key dimensions of your apparatus. For example, if you make something out of the wire, say how big it is and any other details that somebody would need to make something that functions in the same way.
(c) Where you will put your apparatus and how it will be oriented, in relation to the power line.
(d) Specifically what you will measure.
(e) Any calculations and formulas that you will use to determine the power-line current based on your measurements.
Design your apparatus to get a measured voltage amplitude of at least 10 mV if the current in the power line has an amplitude of 1000 A at 60 Hz and the power line is 10 m above ground. Include a calculation to show how much signal you expect to get.Make appropriate approximations to simplify your calculations, and explain why they are valid.
For maximum points, make the apparatus something that one person can carry a few yards and set up on the ground near the power line.(If you need a crane or a tall ladder, there must be an easier way...)You may assume that you know how far the power line is above the ground, but you get bonus points if you find a way to get all the information you need from measurements you make with your apparatus at different positions in space.
also the loop can not revolve/spin to change the flux.
Lenz's law, amperes law,biot-savart law, maxwells equations?
I feel like i am spinning my wheels at the start here. so I figured that i would start with some type of wire loop that I could change its diameter. This would allow there to be a change in flux through the loop creating a current through the wire. i could then read the current through the wire...however I don't know where to go from here.
Here is a cleaner version of the question.
If they wanted to know about the potential of the line with respect to ground, I suppose you'd need to investigate the electric field. But they don't: they want the current flowing along the wire, so you need to look at the field that causes.
  • · Replies 40 ·
