Create Distributed Database w/ MySQL, MS SQL, Oracle & PostgreSQL
The discussion revolves around creating a distributed database system using a heterogeneous setup involving MySQL, MS SQL Server, Oracle, and PostgreSQL. Participants explore methods for connecting these databases at the database level rather than through application-level integration, seeking solutions to facilitate data access across different database platforms.
  • One participant expresses the need to connect MySQL, MS SQL Server, Oracle, and PostgreSQL at the database level and seeks advice on achieving this.
  • Another participant suggests setting up multiple servers, each hosting one database, to facilitate parallel access.
  • A student mentions that no previous group has successfully connected four different databases and seeks guidance on how to allow Oracle to access a MySQL table and vice versa.
  • Several participants inquire about the specific platforms and APIs being used for database access, emphasizing the importance of knowing the connection methods.
  • One participant highlights the Open DataBase Connectivity (ODBC) as a standardized way to connect to various databases, mentioning the availability of libraries for different platforms.
  • There is a question raised about the distinction between connecting databases at the database level versus application level, prompting a discussion on the role of software in accessing database data.
Participants do not reach a consensus on the best approach to connect the databases, and multiple competing views and uncertainties remain regarding the methods and platforms to be used.
Participants have not specified certain assumptions, such as the exact requirements for the distributed system or the limitations of the databases involved. There is also a lack of clarity on the specific programming languages or platforms that will be utilized for the connections.
kawan
I need to create a system using heterogeneous database.
I must use at least 4 different database.
My choice would be MySQL, MS SQL Server, Oracle and PostgreSQL
since these are among the most popular and matured database
or if you have any database that is more suitable please tell me?
I am trying to connect to different database on the database level, not on the application level.
Did you have any ways how to connect all the database become distributed database?
Please help me to solve this problem..
Technology news on Phys.org
Hey kawan and welcome to the forums.
If you want to have different databases being accessed in parallel, why don't you just set up multiple servers having one database each?
All the database on different server..
I am a student, major in database management. On my 5th semester, we are required to create a system using heterogeneous database. We must use at least 4 different database. My choice would be MySQL, MS SQL Server, Oracle and PostgreSQL since these are among the most popular and matured database.
The problem is that so far, no group has ever manage to connect to 4 different database
I am trying to connect to different database on the database level, not on the application level. Using something like Oracle's database link.
how should I deal with heterogeneous database?
i want to make a system that can use various database..
For the example, i create table teacher on MYSQL and i create table student on ORACLE.. How can i do the oracle can access teacher table and mysql can access student table..
Do you have any solution?
Could you outline what kind of platforms you wish to use?
In other words, are you trying to use some kind of dynamic html platform like PHP, ASP, or something similar, or are you using a non-web based application that accesses a database through a connection like ODBC or through some other software library?
For the database access itself, what is the API used to access the database? Is it some kind of Oracle, ODBC, MySQL 3rd party interface?
The thing is that your code no matter what the platform is going to have to make specific calls to access a particular database, and the first step will be to set up a connection of some sort and this connection will specify an address for the database that will include a server of some sort.
How you actually use these databases is going to be up to you, but for the sake of helping you, others need to know these kinds of specific details.
I'm using Windows.
I'm not decided to use what type of langgauge platform..
Because i want connect all the type of database on database level..
Using code in the database platform..
i think you know some way how to connect all the database..
kawan said:
I'm using Windows.
Yes but you have to use some kind of platform. Whether it's PHP with MySQL libraries or C++ with compiled lib files or a DLL with an include file and API documentation, it's still a platform.
There are many different ways to connect to a database depending on the platform and libaries that are used.
One standardized way of connecting to and using databases is the Open DataBase Connectivity (ODBC). There are many libraries for may platforms and languages that allow you to connect and use databases.
Here is something a quick google gave which is a C++ wrapper for ODBC that implements C++ specific features (like namespaces):
http://simpledb.sourceforge.net/doc/index.html
This is a lot more comprehensive:
http://msdn.microsoft.com/en-us/library/windows/desktop/ms714562(v=vs.85).aspx
Having said the above, there are database platforms that have a lot of libraries and features that make complex tasks a lot easier, and if you have specific complex tasks that would be beneficial to utilize in a particular platform, then you should investigate these.
If you are just using an windows EXE, service, DLL or similar, then check out the ODBC API. This will work for any kind of database as long as the database vendor (Oracle, IBM, Microsoft, etc) provide a driver for ODBC that allows a user to connect to that database via the ODBC service. Think of it like a hardware driver, but the hardware in this case is the actual database.
What do you mean by connecting databases on a database level versus application? Software is needed to access the data in a database, so are you separating this software into what is supplied by a database software vendor versus the code written by a user of that database software, and only considering the user written software as being part of an application?
  • · Replies 16 ·
  • · Replies 18 ·
