Creating a Monorail: Electric Fields and Magnetism
To build a monorail suspended by magnets and powered by electricity, understanding electric fields and magnetism is crucial. The propulsion can be achieved using electromagnets, where a permanent magnet on the train is attracted to the electromagnet. By alternating the current direction in the electromagnet, the poles switch from north to south, allowing the train to move forward in a stepping motion. The design should focus on creating a series of electromagnets that effectively attract and repel the train. Mastering these concepts will be essential for successful construction of the monorail.
The Green Giant
Hi,
lately, me and my friend wanted to build a monorail. suspended by magnets, and powered by electricity. we can't manage to create propulson. The Question?
What shape and how are electric fields formed?
P.S. Please don't call me a simpleton, I'm only fifteen.
I'm talking about electromegnets.
You have a challenge ahead of you for the 'suspended' part. Forget it for now.
For the propulsion, that's easier. Let's say you have a bar magnet or a bolt with some wire wrapped around it to make an electromagnet, doesn't matter. You have a north and south pole. The strength will be the best at the ends where each pole is located. Remember likes repel and opposites attract. Your goal should be to first have the permanent magent on the train become attracted to your electromagnet. Then you need to make a series of them and switch them from N to S to make the train 'step' forward from one to the next. You reverse N to S to N by switching the direction the current flows in the coil of your electromagnet.
Here's a recent thread about this:
https://www.physicsforums.com/showthread.php?s=&threadid=15853
Cliff
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
