Crimp vs Compression: Which Hose Fitting is Best for Your Needs?
  • Thread starter Thread starter araanandv2
    Compression
Crimp and compression crimp hose fittings differ primarily in their construction and sealing methods. Flared fittings provide a self-sealing mechanism that enhances leak prevention under high pressure, while compression fittings use a ferrule that bites into the tube, making installation straightforward but potentially less reliable in outdoor settings. The advantages of flared fittings include better long-term leak prevention and lower costs, though they require specific tools and skills for proper installation. Compression fittings are easier to install but can lead to leaks if not done correctly. Overall, flared fittings are preferred for their reliability, especially in fluctuating pressure systems.
araanandv2
Hi,
Please explain ..
What is Crimp amd compression crimp hose fittings?
What are the advantages and disadvantages of flare and flareless fitting?When to go for flare and flareless fittings?
Thanks
Ana
Hi.
I wasn't aware of a difference between 'crimp' and 'compression crimp', other than possibly the materials involved. My experience is limited to having had a couple of custom hoses made up at the local shop. The pressure rating might depend upon how the crimp is created.
Flares act as their own gaskets, so it's easier to seal a high-pressure joint with flared couplers (as evidenced by brake-line fittings). I can't see any disadvantage to using flares, other than the couple of seconds that it takes to create one. You'd have to be pretty desperate for that to dissuade you. The advantage to them over a regular fitting is that line pressure actually helps them to seal by forcing them into the receiver tighter. That isolates the joint itself from the pressure that might otherwise back out between the tube and the collar.
A compression fitting uses a ferrule that bites into the tube. The one big advantage is that there is no special end treatment required to prepare the tube. The installation is a permanent one because once the nut is locked down and the compression fitting sinched in, the ferrule will need to be cut off the tube. The installation is pretty easy to do, but a lot of people don't know the proper methodology. I personally have had leak issues using them in outdoor situations. Swagelok fittings are a very widely used brand of compression fittings and valves. Many places insist on using these fittings.
Personally, I prefer 37 degree flared fittings. I have had better luck with them in leak prevention, especially over long time periods and systems that fluctuate its pressure over wide range. The fittings are a bit less expensive as well. They do require a flaring tool and a bit of talent to make a burr free flare. Some tubing does not flare very well too. Therefore you need to know some special tricks to make them work well (like putting some oil on the flaring tool).
Thanks for the clarification, Fred. I've used compression fittings (on my engine oil gauge, for instance), but didn't know what they were called.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
