Critical speed of a vertical shaft
The discussion centers around calculating the critical speed of a vertical shaft, exploring the influence of support types and shaft orientation on deflection and critical speed. Participants examine theoretical and practical aspects of shaft dynamics, including mathematical relationships and empirical observations.
  • One participant asserts that the critical speed is influenced by the type of supports, suggesting that fixed-fixed supports yield higher critical speeds than supported-supported ones.
  • Another participant claims that deflection is the same regardless of shaft orientation, emphasizing that it depends solely on support type.
  • A later reply references a Wikipedia article, indicating that the critical speed relationship holds true for any shaft orientation.
  • One participant expresses confusion over the relationship between deflection and critical speed, noting that vertical shafts exhibit lower deflection and questioning how this affects critical speed calculations.
  • Another participant provides a formula for critical speed, explaining the relationship between stiffness and mass, and how it can be derived from static deflection measurements.
  • One participant mentions the complexity of measuring stiffness in bending shafts and suggests that maximum deflection is easier to determine for practical applications.
  • A final contribution highlights the existence of extensive literature on shaft critical speeds, mentioning that various methods exist, including Rayleigh's method for more complex shaft geometries.
Participants express differing views on the relationship between shaft orientation, deflection, and critical speed. There is no consensus on how these factors interact, and the discussion remains unresolved regarding the implications of shaft orientation on critical speed calculations.
Participants note that the critical speed calculations may depend on various assumptions, including the nature of the shaft's mass distribution and the specific conditions of support. The discussion also highlights the challenges in measuring stiffness and deflection in practical scenarios.
okinaw
Hi everyone,
I have to calculate the critical speed of a vertical shaft. I have been looking on internet how to calculate, and I have found that this critical speed is based on the type of the supports of the shaft. The type of supports determine the deflection of the shaft (δ) and for this reason a fixed-fixed shaft has a higher critical speed than a supported-supported shaft.
If it is correct, how can I determine the critical speed of a vertical shaft?
Knowing that the deflection of the vertical shaft is lower than the horizontal one, I suppose that the critical speed is going to be higher. Am I correct?
Whether vertical or horizontal, the deflection will be the same. It only depends on the type of supports.
The deflection is actually the static deflection under gravitational loading only when the shaft is horizontal. It is used with ##g## to find the ratio ##k/m (= g/y)## which is the relationship between stiffness and mass of the shaft such that we can evaluate its response to vibrations.
Thanks to both of you,
I read the article of wikipedia but I have some doubts. The article says that the critical speed is calculated approximately as:
ω≈√g/ymax
being:
g=gravity
ymax= static deflections (under gravitational loading only)
Depending on the orientation of the shaft, the deflection is going to be different.(In vertical cases, the deflection is going to be much lower), and this implies higher critical speed. So I can not undertand why the relationship is valid no matter what the orientation of the shaft is.
I did some tests, and the critical speed in vertical shafts is higher but i do not know how to quantify how much higher.
Thanks in advance and happy new year.
The critical speed for any shaft is ##\omega = \sqrt{\frac{k}{m}}##. It relates the stiffness of the shaft (elastic restoring force) vs the inertia of the shaft (centripetal force). It comes from ##kr = m\omega^2r## where the mass of the shaft is assumed to be concentrated at one point where there is a shaft deflection ##r##.
Values for ##k## in a bending shaft can be difficult to measure. But when you take an horizontal beam, you can easily evaluate how it will deform under its own load, usually it's a function ##y(x)## where a ##y_{max}## can be identified. If we assume the mass of the beam is concentrated at one point, say ##x_c##, the only forces involved for a none rotating shaft are ##mg = ky(x_c)## where necessarily ##y(x_c) = y_{max}##. This is the same equation than for our rotating shaft, but with a different acceleration. So we can rearrange the equation to ##\frac{k}{m} = \frac{g}{y_{max}}##.
Therefore, you don't need to know ##k##, as ##y_{max}## is a lot easier to determined.
There is a vast literature available regarding the critical speed of shafts. Look under "rotor dynamics" in a search engine.
There are many different approaches to finding shaft critical speeds. The simple equation proposed by Jack above does not help understanding very much because it relates a single discrete stiffness (k), a single discrete mass (m), to the simple system natural frequency. Actual beams are invariably continuous distributions of both mass and flexibility.
The most common approach to realistic shaft geometries (numerous diameter changes, disks, etc) is via Rayleigh's method. This is detailed in the text by Mischke (Elements of Mechanical Analysis, Addison-Wesley, 1963, p. 279).
11K
9K
