Cumulative distribution function
magnifik
A dart is thrown towards a quadrilateral defined by {(x,y): 0 < x < b, 0 < x < b}. Assume the dart is equally likely to land anywhere within this shape. Let Z be denoted by the (x,y) coordinate with the least value. Find the region in the square corresponding to {Z < z}
so i know the sample space contains any x or y within 0 to b in both directions. and i know that Z = whichever coordinate is the smallest, with a minimum at 0 and a maximum at b. i don't understand how to find where {Z < z} inside the square... wouldn't all the values be within Z? this makes no sense to me
If I give you a value of z in (0,b) it is quite possible for both X and Y to both take values > z, so Z (the smaller of X and Y) would be > z in that case. By the way, you should distinguish between X (the random variable) and x (possible numerical value for X), and between Y and y.
RGV
i'm still confused on how this relates to the area of the square
is z the entire area of the square since it can take on any value from 0 to b in both the x and y directions?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
