Curl of velocity vector in rotational motion
brotherbobby
TL;DR
In rotational motion, ##\boxed{\vec v = \vec\omega\times\vec r}##, irrespective of whether the angular velocity ##\vec\omega## is constant or not (I hope I am correct in saying this). However, the curl of velocity vector, ##\mathbf{\vec\nabla\times\vec v=2\vec\omega}## comes out only to be true if the angular velocity of the rotating body is ##\vec\omega## constant. Is this true? I show the details below.
Attempt :
I draw the diagram of the problem to the right. A circular plate of radius ##a## rotates with an angular velocity ##\vec\omega = \omega_0\hat k##, assumed constant for the moment. A particle P at rest with the plate lies on the rim along the ##x## axis, as shown. Its velocity is ##\vec v= v\hat j## and its position vector ##\vec r = a\hat i##. Using the right hand rule, these vectors make sense : ##\vec v = \vec\omega_0\times\vec r\Rightarrow v=\omega_0 a##, remembering that ##\hat j = \hat k\times\hat i##. Calculating the curl of this vector using index notation, ##\small{\vec\nabla\times\vec v = \vec\nabla\times(\vec\omega_0\times\vec r)=\epsilon_{ijk}\partial_j(\vec\omega_0\times\vec r)_k\hat e_i = \epsilon_{kij}\epsilon_{klm}\partial_j\,\omega_{0_l}\,x_m \hat e_i=(\delta_{il}\delta_{jm} -\delta_{im}\delta_{jl})\partial_j\,\omega_{0_l}\,x_m \hat e_i}##, which reduces to ##\small={\partial_j\,\omega_{0_i}\,x_j \hat e_i-\partial_j\,\omega_{0_j}\,x_i \hat e_i=3\vec\omega_0-\vec\omega_0=2\omega_0}\Rightarrow \boxed{\vec\nabla\times\vec v=2\vec\omega_0}##, where I have used the fact that ##\vec\omega_0## is uniform and ##\partial_i x_j = \delta_{ij}##. This can also be shown using the method of determinants for the cross product.
Question : Clearly, from my derivation, the angular velocity ##\vec\omega_0## is constant. Does it have to be? In which case, I am mistaken in what I have shown. Can it not be that the curl of the velocity vector at a given time ##t## equals twice the angular velocity at that time : ##\vec\nabla\times\vec v(t)=2\vec\omega(t)##?
Constant with respect to what? Time or position? If ##\omega## varies with respect to r, then curl is different than when it doesn't. If ##\omega## varies with respect to t, then so will the curl.
See also:
brotherbobby said:
Clearly, from my derivation, the angular velocity ω→0 is constant
It is not clear to me. What step breaks if it is not constant wrt time?
By definition, ##\vec \omega## is constant is space - or you don’t have rotational motion. The curl does not contain derivatives wrt time so clearly letting ##\vec \omega## have a time dependence does not affect the result here.
Space.
So if the angular velocity of the body varies with time, say ##\vec\omega(t)##, I have the following two questions. The first one is more basic and I suppose more important :
  1. Can we write ##\vec v(t)=\vec\omega(t)\times\vec r(t)##? Of course the position vector and linear velocity of the point P, viz. ##\vec r(t)\,,\;\vec v(t)## on the body varies with time even if the angular velocity ##\vec\omega## was some constant (##\vec\omega_0##).
  2. Is the curl of the linear velocity twice the angular velocity, i.e. ##\vec\nabla\times\vec v(t)=2\vec\omega(t)##? Given my derivation above, I just don't see how that is.
Thank you, and a bit silly on my part. My derivation up there in post#1 remains the same even if the the angular velocity vector ##\vec\omega(t)## changed with time. Hence, I suppose it would be ok for us to write that ##\vec\nabla\times\vec v(t)=2\vec\omega(t)##.
Yes I agree with the second sentence of yours. It is the first that is more interesting.
Let me write it again, despite being repititive.
The angular velocity vector of a rotating body ##\vec\omega## is necessarily a constant in space. Thus it would be quite nonsense to write ##\vec\omega(\vec r)##.
What if a body was precessing - i.e. the rotating axis changing with time. Can we write its angular velocity ##\vec\omega## to be a function of position ##\vec r## or angle ##\theta##?
No. It is a function of time as it changes with time, but it does not depend on spatial coordinates. If it did the object would necessarily change shape.
The angular velocity of a rigid body is defined by the Euler formula:
$$\boldsymbol{v}_A=\boldsymbol v_B+\boldsymbol\omega\times\boldsymbol{BA}.\qquad(*)$$
The vector ##\boldsymbol\omega## can depend on time, but it is independent of any spatial variables. And, indeed, if ##\boldsymbol v## is a velocity field in a rigid body, then ##\boldsymbol \omega=\frac{1}{2}\mathrm{curl}\,\boldsymbol v##. This fact follows directly from (*).
To check it consider ##\boldsymbol{BA}=(x-x_B(t),y-y_B(t),z-z_B(t))## and
##\boldsymbol v(x,y,z)=\boldsymbol v_A##
In continuum mechanics, one defines the vector field
\boldsymbol{\omega} = \frac{1}{2}\,\nabla \times \mathbf{v}.
$$ It measures the local rotation of a material particle.
In the case of a deformable medium, this vector field may vary in space.
However, a defining property of a rigid (undeformable) body is that the vector field ##\boldsymbol{\omega}## is uniform throughout the body. All particles in a continuous, undeformable medium rotate on their own axis in the same way.
You are free to consider a velocity field of the form
\mathbf{v} = \mathbf{A} \times \mathbf{OM},
with ##\mathbf{A}## a non-uniform vector field. But in that case, this velocity field cannot correspond to that of a rigid body.
For example, in cylindrical coordinates, one could take: ##\mathbf{A} = r\,\mathbf{e}_z,##
which gives :
\mathbf{v} = (r\,\mathbf{e}_z) \times \mathbf{OM} = r^2\,\mathbf{e}_\theta.
As one moves away from the origin, the velocity increases faster than in the rigid-body case.
In this case, if you compute
\boldsymbol{\omega} = \frac{1}{2}\,\nabla \times \mathbf{v},
you will find that ##\boldsymbol{\omega} \neq \mathbf{A}. ##
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 42 ·
  • · Replies 18 ·
