Adding I1,I2,I3,I4 to Get I5 - Tips & Tricks
  • Thread starter Thread starter Matty9879
    Addition Current
I5 is calculated as I3 - I4 + I2 + I1, confirming the conservation of electric charge. The discussion emphasizes that current should be viewed as a flow, where the total current at a point is the sum of incoming currents minus outgoing currents. It is clarified that all currents entering a junction are considered positive, while those leaving are negative. The final value for I5 is determined to be -12A, adhering to the established rules of current flow. Understanding these principles is essential for accurate calculations in electrical circuits.
Matty9879
What is I5 I think its I3-I4+I2+I1 but not surehow to add em up any tips?
thanks
Yes,it is correct.Electric charge is conserved.With the regular choise of signs,the I_{5} should be -12A.
Daniel.
Think of current as water flow. The current at a point is the sum of all currents entering at that point minus all currents leaving that point. Your answer is correct.
AM
Thanks for the reassurance but by the way it wasnt neative
It had to be.That's the rule.All currents entering a vertex are positive,while all which are leaving are negative.
Daniel.
