Current Decay in an R-L Circuit
The discussion revolves around calculating the time it takes for the stored energy in an ideal solenoid to reach half of its maximum value after closing a switch in an R-L circuit. The user correctly calculates the inductance, current, and maximum energy stored in the solenoid but struggles with the time calculation. They mistakenly apply an equation meant for energy decay, which does not fit the scenario where energy increases from zero to a maximum. The correct approach involves finding the current as a function of time to derive the energy stored in the inductor over time. Clarification emphasizes that the energy starts at zero and increases, contrasting with the decay model initially used.
sdalglish13
I was trying to solve this problem the other day for my physics class and I keep getting the wrong answer. The problem is as follows:
An ideal solenoid is 18.5 cm long, has a circular cross-section 2.20 cm in diameter, and contains 545 equally spaced thin windings. This solenoid is connected in a series circuit with a 15 ohm resistor, a battery of internal resistance ohms and open-circuit terminal voltage of 25 V, and an open switch. (Note u = 4*(pi)*10-7 T *m/A)
How long after closing the switch will it take for the stored energy in the solenoid to reach 1/2 of its maximum value?
So this is what I did:
L = (u0N2A)/l
where L = inductance in Henry
N = number of turns
A = area of cross-section
l = length in meters
L = (4*(pi)*10-7 )(5452)(3.8*10-4)
.185
L = 7.66 *10-4 H
Then I found the current I:
I = emf/R
where emf = electromotive force/voltage
R = resistance
I = 25 Volts/(15 ohms + 5 ohms) = 1.25 Amps
Next I used the energy equation to find the maximum energy:
U = 0.5*L*I2
where U = energy
L = inductance
I = current
U = 0.5*(7.66 *10-4)*(1.252)
U = 5.99*10-4 J
Then I don't know where to go from there to find time. I already tried an equation I found in my textbook...
U = U0e-2*(R/L)*t
t = -ln(.5)*L/(2R)
t = -ln(.5)*(7.66 *10-4)/(2*(15+5))
t = 1.32*10-5 sec
and solved for t that way, but I keep getting 1.32*10-5 sec, when the answer should be t = 4.71 *10-5. I know t = 4.71 *10-5 is the correct answer because it came off of the answer sheet for a review.
Can anyone shed some light on what I am doing right/wrong?
You need to find the current as a function of time and use it to calculate the energy stored in the inductor as a function of time.
The equation you tried doesn't apply to this situation. For one, it starts at U0 and decays to 0, but in this circuit, the energy starts at 0 and increases to the max value you found as t goes to infinity.
