Current flowing from point A in a circuit to point B
5 replies · 2K views
FADFAD1
A current at point A of 2A flows through a resistor (3 ohms), a battery of 20V (negative terminal first), another resistor (1 ohm) and a battery of 6V (positive terminal first). What is the potential difference between A and B
I used a negative voltage for when it passes through the first resistor then added 20V through the battery but it doesn't seem right
I think you are correst.
I would say that a current of 2A flows from the rest of the circuit through point A into the 3Ω resistor. Point A has to be more positive than the other side of this resistor to make such a current flow.
That is 100% correct. Just keep going. So far you have..
-(2*3) + 20 ...
It might help if you draw the circuit, labeling the voltage drops (or rises) for each device.
You said you did not get the correct answer. (actually you said it doesn't seem right, sorry).
What answer did you get? How did you arrive at that answer? If we can see that, then we can better guide you to where the mistake is.
If current flows through a resistor from left to right, then the left side will be at higher (more positive) potential than the right. Flow through a battery depends on the polarity of the battery. If it goes from negative terminal (through the battery) to positive, then it is a voltage rise.
