Solving q(1.204): Charge Flow in Circuits
The discussion focuses on solving the equation for charge flow in circuits, given by q(t) = [3e^(-t) - 5e^(-2t)]. The user calculates the current i by taking the derivative of q with respect to t, resulting in i = -3e^(-t) + 10e^(-2t). A key point raised is the need for clarification on what specific value of t is required, such as when the charge is at a maximum or minimum. It is emphasized that without additional information, further calculations cannot be performed. The conversation highlights the relationship between charge, current, and time in circuit analysis.
Sajjad
The charge flowing through a circuit is
q(t)=[3e^(-t) - 5e^(-2t)]--------(1)
find the value of t and then current i.
as i=dq/dt.
i am doing it like this
i=-3e^-t + 10e^-2t.....taking derivative
let e^-t=u...for eaze
i=10[u^2-3u/10]
let 1=0 then
10[u^2-3u/10]=0
10[u^2 - 2(u)(3/20) + (3/20)^2 - (3/20)^2]=0 ...using formula
10[u-3/20]^2 - 10[3/20]^2=0
10[u-3/20]^2=10[3/20]^2
10[u-3/20]^2=9/40
[u-3/20]^2=9/400
u-3/20=sqrt[9/400]
u=sqrt[9/400] + 3/20
e^-t = 3/20 + 3/20...as u=e^-t
Taking log on both side
ln[e^-t]= ln[3/10]
-t= -1.204
t= 1.204 seconds |------ am i doing ok till here?
by putting this in equation 1 we will get the vale for charge,q.
What do you mean find the value of t? The value of t when what happens?
i think!
everyone knows that i= q/t in general but to find current i at some instant we have i= di/dt. In the given equation above if we can find the value of t we can put this value of t back in the equation and can find the charge q. by having charge q and time t, current i can be found by using formula i=q/t and the value of t can only be determined by taking derivative of the equation. at least i see only this possibility.
So basically you have
q(t) = 3e^{-t} - 5e^{-2t}
q '(t) = 10e^{-2t} - 3e^{-t}
You now can't solve any further without having more information. As berkeman said, when do you need to know t? Do you want to find t when q is maximum / minimum etc.
