Curves, relationships, functions and symmetry
mariechap89
For the following curves i) y=x^2+4x-1 ii) y=-2+or-Square root(x+5)
a) Sketch both the curves on the same sheet of graph paper- against the same axis
I have done this, although I have not shown it here
b) Determine with proof, whether the above curves are related.
Not sure how to do this.
c)Determine with proof, if either of the above curves are a function
Not sure how to do this either.
d)Determine, with proof, whether either of the curves displays odd or even symmetry
y=f(x)=x^2+4x-1
f(-x)=-x^2+4x-1
Even function
Is this correct
Any help would be great thanks
What did you notice about the two graphs in part a?
Surely you have learned how to tell whether a graph represents a function. Does the phrase "vertical line test" ring a bell?
y=f(x)=x^2+4x-1
f(-x)=-x^2+4x-1
Even function
Is this correct
A function is even if f(-x) = f(x) for all x in the domain of the function. A function is odd if -f(-x) = f(x) for all x in the domain of the function. You have not calculated f(-x) correctly. Please try again.
If y= 2\pm\sqrt{x+ 5} then y- 2= \pm\sqrt{x+ 5} and, squaring both sides, (y- 2)^2= y^2- 4y+ 4= x+ 5 which is exactly the same as y^2- 4y- 1= x. How is that formula connected to y= x^2- 4y+ 1?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
