D.E.: Reduction of Order: Non-shortcut method question
  • Thread starter Thread starter Jeff12341234
    Method Reduction
Jeff12341234
I don't know what to do with the x^3*e^x on the left side of the page. In the example the instructor gave for a different problem, you couldn't solve for x. In this problem you can so what does that mean I need to do with it?
Is this answer correct?
Yes, it is :)
So do you always just ignore the factor that doesn't contain the u(x) function like I just did in this example?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
