Is the D.E. Solution Affected by the Presence of a Non-Homogeneous Term?
  • Thread starter Thread starter Darkmisc
    Damped Systems
Darkmisc
Let ay'' + by' +cy = R(x)
Determining whether a system is under/over/critically damped depends on the size of b^2 compared to 4ac.
Does it depend at all on R(x)?
Characteristic equation, quadratic equation.
I've found a general solution to a D.E. where b^2 < 4ac, and is therefore underdamped (if the D.E = 0)
However, I'm not sure if I can still conclude that the system is underdamped if the D.E. = R(x).
Look after the definition of being under/over/critically damped.
ehild
No, it does not. As ehild suggests, surely the definition of "under/over/critically damped" is given in your text?
Thanks. The defintion only referred to b^2 - 4ac without explicitly stating that R(x) was irrelevant to damping.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
