Damped harmonic oscillator, no clue
The discussion revolves around solving the equation of motion for a damped harmonic oscillator with given parameters and initial conditions. The user needs to determine the resistance (R) and spring constant (K) based on the provided velocities at specific times. The approach involves rewriting the equation in standard form to identify whether the system is underdamped or overdamped, using the damping ratio (ζ) to guide the solution. The proposed method includes deriving the position and velocity equations and applying the initial conditions to find R and K. The complexity of the calculations is acknowledged, with no straightforward solution readily available.
Smity
I have a ball of 20 kg describing a damped harmonic movement, ie,
m*∂^2(x)+R*∂x+K*x=0,
with m=mass, R=resistance, K=spring constant.
The initial position is x(0)=1, the initial velocity is v(0)=0.
Knowing that v(1)=0.5, v(2)=0.3, I have to calculate K and R.
2. The attempt at a solution
I know that if R^2 < 4*m*K, the solution with x(0)=1 and v(0)=0 is such that:
∂x(t)=exp(-R/(2*m)*t)*[-(R/(2*m)^2)/(√[K/m-(R/(2*m))^2])-√[K/m-(R/(2*m))^2]]*sin(√[K/m-(R/(2*m))^2]*t), and I solve the sistem of equations, but it has to be a simpler way to do it (and also I don't use the mass of the ball)
Thanks!
First, realize that you may have an underdamped or overdamped system. The criterion for underdamped is ζ < 1. For this case, rewrite your equation as follows: (m/K)x" + (R/K)x' + x = 0
Let
m/K = 1/ω12
R/K = 2ζ/ω1
so your equation becomes, in "standard" form,
(1/ω12) x'' + 2ζ/ω1 x' + x = 0
with initial condition x(0+) = 1
with solution
x(t) = ω12exp[(-ζω1t/√(1-ζ2)] sin[ω1√(1-ζ2)t + ψ],
where ψ = arc tan √(1-ζ2)/(-ζ).
This is the solution of the "standardized" equation above.
Now take (d/dt) of this to get x'(t),
then impose x'(1) = 0.5 and x'(2) = 0.3.
If you succed in getting positive real numbers for R and K you are done.
But it's possible you may have an overdamped (or critically damped) case, in which case rewrite your equation as
T1T2 x'' + (T1 + T2) x' + x = 0
for which the solution would be
1/T1T2(T1 - T2) [T1exp(-t/T2) - T2exp(-t/T1)].
Again, take x'(t) from that and force the two conditions on x'(1) and x'(2).
You have some messy math ahead of you and I don't see a simple way to avoid it unless you can find a pre-cooked solution somewhere. I don't know any such place.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
