What are some companies that make super low-power step-down converters?
  • Thread starter Thread starter Jdo300
    Converter
The discussion focuses on finding super low-power step-down converters for a 5V, 7mA application on a PCB powered by either a 5V isolated supply or an 18V non-isolated supply. A linear regulator is currently used, but the inefficiency is a concern due to battery operation. Recommendations include the National Semi LM5009 buck converter, noted for its potential efficiency at low currents, though the efficiency data is limited below 50mA. Linear Technology is highlighted as a leading manufacturer for converters, with switching converters offering significantly better efficiency compared to linear options. The conversation suggests exploring custom buck circuits and reviewing relevant application notes for further insights.
Jdo300
Hello All,
I have a situation where there is an IC that takes 5V at 7mA on an isolated area of my PCB. I have two DC supply sources to choose from to power this chip; either a 5V supply (which has to be isolated from this chip) or an 18V supply which doesn't need to be isolated from it.
I currently have a simple linear regulator to drop the voltage from the 18V side down to 5V, but since my board runs on batteries (two 9Vs to be specific) I don't want to waste any extra power if I can help it. Would any of you happen to know of any companies who make super low-power step-down converters? I was looking on Mouser/Digikey for the small monolithic ones with all the guts in them but the lowest I could find were 1W units. and if I only draw like 7mA from it, the efficiency would be so bad that it wouldn't be worth using.
I also am thinking that some kind of charge pump may work since the power is so low but I have yet to find any step-down charge pumps.
Thanks,
Jason O
That is a tough design point. Have you looked at the National Semi LM5009 buck step-down converter?
http://www.national.com/pf/LM/LM5009.html
It looks to be their lowest-power buck. The efficiency plot on this web page implies that it may still be pretty efficient down at 7mA, but the plot doesn't go below 50mA (the datasheet should have a better plot, and a listing of the Iq for the part, which will limit the low Iout efficiency.
Beyond that, the linear approach seems your best bet. Or you could home-brew your own step-down buck circuit, optimized for very low Iq. What are your regulation and ripple requirements for this 5V IC?
Linear Technology IMO is the best company in the industry for converters. A switching converter will get you 85% efficient against your 5V*7ma load, for a Pin of 41mw. If you use a linear you must waste the drop 13V*7ma, for an Pin of 126mw or ~3x worse.
http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1042,C1032,C1064,P49784
When you have a moment read Williams' '..Converters for Poets' app note. Its a master piece on the subject, along w/ most of his app. notes.
http://www.linear.com/designtools/app_notes.jsp
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
