Connecting 12V DC Motor to Two 9V Batteries
Connecting a 12V DC motor to two 9V batteries in series, resulting in 18V, is generally not recommended. The motor, rated for 3V to 12V and designed for applications like air blowers, could run excessively fast at 22,500 RPM, leading to potential overheating and damage. Power consumption increases significantly with RPM, risking the motor's integrity if the load isn't reduced. A better approach is to use a voltage regulator or PWM control to maintain the motor at 12V. Using a single 9V battery may be more suitable given the motor's specifications.
cyril joel
Hello i am abeginer i have to connect a 12v dc motor can i connect it to two 9v batteries in series meabs a total output of 18V.
Welcome to the PF.
In general, the answer would be no. But in some cases it might be okay. Do you have the specification sheet for the 12V DC motor?
Also, you can buy modules to convert your 18V supply down to the 12V needed for the motor. What current is the motor rated for? What is the application? :smile:
Welcome to the PF.
The motor is rated 3v to 12 v 15000 RPM and medium size the application is an air blower
The motor would try to run 50% faster on 18V than 12V. So it might try and go 22,500rpm
The power absorbed by a propeller is proportional to rpm cubed (http://www.eaa62.org/technotes/prop.htm) so unless you reduce the size of the load (fan) you might be asking the motor to deliver more than three times it's rated power...
(22500)3/(15000)3 = 3.4
If it's an intermittent duty cycle, it might work, but any extended run it'll probably suffer from overheating... Depending on the control system you have for it, you could run a PWM (Pulse width modulation) at about 66%, and it would give you an average of 12V.
If you're thinking of the typical 9V battery in most multimeters and electronics, etc, I think battery life would be very short too.
So your really hooking up a 3-12v motor? Why not just use one 9v battery?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
