For what m is the complex number $(\sqrt 3+i)^m$ positive and real?
The discussion focuses on finding integer values of n for which the equation (\sqrt{3}+i)^n = 2^{n-1}(-1+\sqrt{3}i) holds true. The conversion to complex exponential form reveals that the angles must match, leading to the equation n(\pi/3) = 2\pi/3, which suggests potential solutions like n = 2, 8, 14, etc. However, a miscalculation regarding the angle for \sqrt{3}+i is identified, correcting it to 2e^{(\pi/3)i}. The final goal is to determine for which m the expression (\sqrt{3}+i)^m is positive and real, with the correct interpretation of the equation leading to insights about the periodic nature of complex exponentials.
Santilopez10
Find all $$n \in Z$$, for which $$ (\sqrt 3+i)^n = 2^{n-1} (-1+\sqrt 3 i)$$
$$ (a+b i)^n = |a+b i|^n e^{i n (\theta + 2 \pi k)} $$
First I convert everything to it`s complex exponential form: $$ 2^n e^{i n (\frac {\pi}{3}+ 2\pi k)} = 2^{n-1} 2 e^{i (\frac{2 \pi}{3} +2 \pi k)} $$
this simplifies to $$ e^{i n (\frac {\pi}{3}+ 2\pi k)} = e^{i (\frac{2 \pi}{3} +2 \pi k)} $$
I know how to find an expression for n, but not that it`s only in the field of ## Z ##, any help would be appreciated, thanks!
Hint: There is no point to writing out the ks. Instead, try to figure out when the numbers are equal without using them. Also, if you do use them, you cannot assume that they are the same on both sides.
Well I would get $$ n \frac {\pi}{3} = \frac {2 \pi}{3} $$
which is true for n = 2, n =8, n= 14, n= 20 ... 2+6t if I am not wrong, but this still does not satisfy the answer provided by the book which is n= 4(1+3t) I am missing a 2!
Actually that equation is only true for n = 2, but that's beside the point.Your primary difficulty lies in the fact that the ## \ \dfrac \pi 3 \ ## is incorrect.
## \sqrt{3} + i \ne 2 e^{(\pi/3)i} ##
Rather: ##\ 2 e^{(\pi/3)i} = 1 +i\sqrt{3} \,.##
Thanks, now I got the correct answer. By the way, when I mentioned the various answers for n it was in the context of angles, not numbers a s a whole.
I would rewrite the right hand side
$$(\sqrt 3+i)^n = 2^{n-1} (-1+\sqrt 3 i)$$
$$(\sqrt 3+i)^n = 2^{n-4}(\sqrt 3+i)^4$$
for what m is
$$(\sqrt 3+i)^m$$
positive and real?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
