Debye model and dispersion relation
c299792458
I have seen case studies of the 3D Debye model where the vibrational modes of a solid is taken to be harmonic with dispersion relation \omega = c_sk. It is said that for temperatures much less than the Debye temperature, the heat capacity at constant volume C_V\sim T^3.
Now I want to show that for bosons with dispersion relation \omega\sim A\sqrt k has heat capacity C_V\sim T^4 for T\ll T_{Debye}.
In the case studies I have read, I can't find where the dispersion relation comes into play. I have no idea how to see this. Please help!
Debye Temperature is given by T_{Debye}k_B=\hbar \omega_{max}
Generally, I know I need to get the density of modes -- I have a suspicion that here is where the dispersion relation kicks in, but I don't know how.
After that, I should find the ultraviolet cutoff frequency \omega_{max}.
Then I should find the energy $$E=\int_0^\omega{max}d\omega {E(\omega)g(\omega)\over \exp(\beta(E-\mu))-1}$$ But what form does $E$ in the integrand take? I know that for photons with dispersion relation \omega = c_s k we have E=\hbar \omega.
After that, it's just a matter of taking limits and C_V=\left({\partial E\over \partial T}\right)_V (should) give the required result...
Please, somebody?
OK, so I know that the density of state depends on the dispersion relation. What are the general definitions of E, p in terms of \omega, k? E.g. for the first case E=\hbar \omega and p=\hbar k. So the question is: what are the respective values for E,p in general?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
