Decibel / Intensity Problem, How do I approach it? .
The discussion revolves around calculating sound intensity and amplitude for sound levels of 70 dB and 50 dB at a frequency of 500 Hz. Participants emphasize the need to show work to receive helpful hints and guidance. The user struggles with understanding the inverse logarithmic function necessary for these calculations. Clarification on logarithmic functions and their inverses is sought, particularly in relation to using a calculator. The conversation highlights the importance of foundational knowledge in sound intensity calculations.
Ishu
Decibel / Intensity Problem, How do I approach it? ASAP.!
I have a question, I don't know how to approach it.. I couldn't find a way..
1.Suppose that the sound level of a conversation is Initially at an angry 70 dB and then drops to a soothing 50 dB. Assuming that the frequency of the sound is 500 Hz, determine,
a. Initial and final sound intensities
b. Initial and final sound wave amplitude.?
Can anyone help me please..:cry:
I know that... But...i mean is theer any inverse log? I don't see in my calculator?
Now that you have seen some useful theory... What have you tried so far? You need to show some work before you will see a deluge of helpful hints on the forum. :wink:
Yes sir, I did tried. But when I do...It coems to a point where I have to take inverse of log... and I don't think there is inverse function for log..
Or is there? If yes how to do in calculator?
Or am i on wrong way?
loga x = y <=> ay = x
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
