Defining functions in terms of differential equations
Sigma057
I have set myself the task of teaching my Freshman in high school brother Calculus, and today while reviewing some topics I saw something I didn't see before.
To start out, I let y = ln[x] => x = e^y
Obviously, we know that y' = 1/x = e^-y
So, I "discovered" that one can define the natural logarithm as the solution to the IVP
y'[x] = e^-y[x], y[1]=0
I know this is a somewhat trivial example,
But my question is, is there anything to be gained by defining functions in this way in general?
Mathematics news on Phys.org
Absolutely! Check out https://www.physicsforums.com/showthread.php?t=105050. It's kind of a long thread about the proof of the orthogonality of Legendre polynomials. I attached a pdf there (mine is the fifth message) showing such a proof which relies solely on the fact that Legendre polynomials satisfy a particular differential equation.
Hi !
almost all elementary and special functions can be defined in several ways, for example : integral, differential equation, series, inverse of an already defined function, etc.
This allows to prove many relationships. Using a convenient definition often simplifies the calculus or developments.
Comming back to the differential équations, a list of the most common cases is presented in the pdf "Safari in the Contry of Special Functions":
http://www.scribd.com/JJacquelin/documents
The differential equations appear pp.30-36 in Table 1 : usual functions, Table 2 : special polynomials, Tables 6-9 : examples of special functions.
You can, for example, define "cos(x)" as "The solution to the differential equation, y''= -y, with initial conditions y(0)= 1, y'(0)= 0". You can similarly define "sin(x)" as "The solution to the differential equation, y''= -y, with initial conditions y(0)= 0, y'(0)= 1.
You can, then, prove all of the properties of those functions from those definitions.
This is better, for example, than just "arbitrarily" extending the usual "right triangle" definitions, which, of course, require that the angle be between 0 and 90 degrees, to any value of x.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
