Degeneracy and commuting observables
foxjwill
Theorem 5 of a text I've been reading that I downloaded from online (for interested parties, the link (a pdf) is http://bohr.physics.berkeley.edu/classes/221/0708/notes/hilbert.pdf) says that
"If two observables A and B commute, [A, B] = 0, then any nondegenerate eigenket of A is also an eigenket of B. (It may be a degenerate eigenket of B.)"​
What I don't understand is how the eigenket could be degenerate in B. I am assuming, I hope correctly, that by "degenerate eigenket" the author means "an eigenket in a degenerate eigenspace". My line of thought is as follows:
Since [A,B]=0, A and B have the same eigenbasis and therefore the same eigenspaces. But then because the degeneracy of an eigenspace is defined to be its dimension, any degenerate eigenspace of A must also be a degenerate eigenspace of B, and vice-versa.
Well, say A is nondegenerate, then B's matrix elements are all diagonal in A's representation
You can see it quite fast, by sandwiching the commutator between two basekets.
Well considering A as nondegenerate might not help, because it switches A and B in the problem...
You can see what quite fast?
Hi foxjwill,
I'm not totally sure I understand the question and the setup. As you say, the wording is a bit poor, but let me give it a shot.
I believe what you're looking for can be illustrated with the simple example of a particle moving on a line. Let A = p (momentum) and B = p^2 so that [A,B] = 0. Eigenvalues of A are all non-degenerate, but eigenvalues of B are all two fold degenerate except for p = 0.
Thus any eigenstate of A belonging to a non-degenerate eigenvalue (in this case, all of them) is an eigenstate of B. However, an eigenstate of B like |p>+|-p> (which is degenerate with |p> - |-p>, for example) is NOT an eigenstate of A, hence the non-degeneracy condition is important.
Hope this helps.
Physics Monkey said:
Hi foxjwill,
Hope this helps.
That definitely helps. What I think is holding my back is that I had taken "simultaneous eigenbases" to mean "the same eigenbasis". Which brings me to the next question: What does "simultaneous eigenbases" mean?
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
