Solving Del Cross Question: Why is del x dB/dt = mu dJ/dt?
  • Thread starter Thread starter miew
    Cross Del
The discussion centers on the relationship between the curl of the magnetic field and current density in electromagnetism. The user questions whether the equation del x dB/dt = mu dJ/dt holds true given del x B = mu J. A response confirms that this equality is valid because derivatives with respect to independent variables can be interchanged. The clarification helps the user understand the reasoning behind the equation. Overall, the conversation emphasizes the commutative property of derivatives in the context of electromagnetic equations.
miew
I have to do an E&M problem, I think I got it, but I made a few steps that I don't really understand. The first one is:
If delxB= muJ
Does
del x dB/dt = mu dJ/dt ??
If so, why ?
I tried using latex, but it didn't work...sorry :(
hi miew! :smile:
(have a del: ∇ and a curly d: ∂ and a mu: µ :wink:)
yes, because derivatives wrt independent variables always commute (ie you can always change the order) …
2/∂x∂t = ∂2/∂t∂x :wink:
Thanks ! that makes sense :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
