Delta-Epsilon Multivariable
In summary, the conversation discusses finding a disk with center (1,1) such that whenever P is in that disk, |f(P)-5|< \epsilon. The attempt at a solution involves rewriting the function and finding the radius of the disk contained within the given rectangle. It is noted that there are an infinite number of disks that will work.
dtl42
119
Let f(x,y)=2x+3y.
Let [tex]\epsilon[/tex] be any positive number. Show that there is a disk with center (1,1) such that whenever P is in that disk, [tex]|f(P)-5|< \epsilon[/tex]. (Give [tex]\delta[/tex] as a function of [tex]\epsilon[/tex].)
None.
Um, I tried to rewrite stuff in a form that's needed, but I can't really get anything. My trouble with these problems is setting everything up and then rearranging it cleverly to get what we need.
[tex]
|f(x,y) - 5| = |(2x-2)+(3y-3)| \le 2|x-1| + 3|y-3|
[/tex]
so now ...
So that is epsilon? How would we find the radius of the disk then?
statdad said:
[tex]
[/tex]
so now ...
The form statdad gave gives you almost immediately the dimensions of a rectangle that will work. Can you find the radius of a disk that will be contained in that rectangle?
By the way, you say "the" disk. You are only asked to find the radius of "a" disk. There are an infinite number that will work.
1. What is Delta-Epsilon Multivariable?
Delta-Epsilon Multivariable is a mathematical concept used in calculus to define the limit of a multivariable function. It involves using two variables, delta and epsilon, to determine the closeness of a particular point to the limit point.
2. Why is Delta-Epsilon Multivariable important?
Delta-Epsilon Multivariable is important because it provides a rigorous and precise definition of the limit of a multivariable function. This allows for more accurate calculations and a deeper understanding of the behavior of functions with multiple variables.
3. How is Delta-Epsilon Multivariable used in calculus?
In calculus, Delta-Epsilon Multivariable is used to prove the existence of a limit and to evaluate the limit of a multivariable function. It is also used to prove continuity and differentiability of multivariable functions.
4. What are the key components of Delta-Epsilon Multivariable?
The key components of Delta-Epsilon Multivariable are the delta and epsilon variables, which represent the distance between a point and the limit point, and the value of the function at that point, respectively. These components are used to determine the limit of the function.
5. Are there any limitations to Delta-Epsilon Multivariable?
While Delta-Epsilon Multivariable is a powerful tool in calculus, it does have some limitations. It can only be applied to continuous functions, and it may not be applicable to more complex functions or in certain situations, such as when dealing with infinite limits.
