A Dependence of loss factor tan(δ) upon H in MnZn ferrites
  • A
  • Thread starter Thread starter H Tomasz Grzybowski
    Loss
The discussion centers on the applicability of the formula Δ(tan(δ)) = ηB⋅ΔB⋅μe for MnZn ferrites, specifically regarding the constant ηB as a hysteresis material constant. Participants are questioning the limits of this formula when using ferrites with an initial permeability (μi) of around 2000. There is a particular interest in determining the magnetic field strength (H) at which the loss factor tan(δ) increases linearly with magnetic flux density (B). Additionally, members are sharing links to ferrite datasheets for further insights. The conversation emphasizes the need for clarity on the relationship between these variables in practical applications.
H Tomasz Grzybowski
There is ηB constant given as a hysteresis material constant.
But there is the question: what is the limit of applicability
of the formula Δ(tan(δ)) = ηB⋅ΔB⋅μe?
In particular I think I want to use ferrite with μi = 2000 or so.
Up to what H value will tan(δ) increase linearly with B ?
Can you post links to the ferrite datasheets that you've been reading to try to answer this question? Thanks.
Here is a link to ferrite data sheet: http://www.cosmoferrites.com/Downloads/Alnh/CF139.pdf
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
