Derivation of Lagrangian in the calculus of variations
The discussion revolves around the derivation of the Lagrangian in the context of the calculus of variations. Participants are examining the expression involving the derivative of the Lagrangian with respect to a perturbed variable.
  • The original poster attempts to apply the chain rule to derive a specific expression related to the Lagrangian. They express uncertainty about evaluating the partial derivative at a specific point and question how to proceed with the dependence of the Lagrangian on the perturbed variable.
  • Some participants question the appropriateness of using a partial derivative in this context and suggest that the Lagrangian should be treated as a function of a single variable.
  • Others propose considering a Taylor series expansion to express the Lagrangian in terms of its derivatives with respect to the variable.
The discussion is ongoing, with participants exploring different interpretations of the problem and suggesting various approaches. There is no explicit consensus, but some guidance has been offered regarding the use of Taylor series and the nature of the Lagrangian's dependence on its variables.
Participants are navigating the complexities of differentiating functions in the context of variational calculus, with some expressing concerns about the assumptions made regarding the variables involved.
Joggl
##\frac {d} {d\epsilon}\left. L(q+\epsilon \psi) \right|_{\epsilon = 0} ##
where the index ##\epsilon = 0## means the derivative of the function evaluated at this point.
##q=q(t)##
##\psi = \psi (q(t), \dot{q}(t), t)##
Hello. In a chapter of a book I just read it is given that
##\frac {d} {d\epsilon}\left. L(q+\epsilon \psi) \right|_{\epsilon = 0} = \frac {\partial L} {\partial q} \psi ##
While trying to get to this conclusion myself I've stumbled over some problem.
First I apply the chain rule:
##\left.(\frac {\partial L(q+\epsilon \psi)} {\partial (q+\epsilon \psi)} \frac {d (q+\epsilon \psi)} {d \epsilon}) \right|_{\epsilon = 0} ##
The second part of the product can be evaluated since ##q## and ##\psi## do not depend on ##\epsilon##:
##\frac {d (q+\epsilon \psi)} {d \epsilon} = \psi##
This leads to:
##\frac {d} {d\epsilon}\left. L(q+\epsilon \psi) \right|_{\epsilon = 0} = \left.(\frac {\partial L(q+\epsilon \psi)} {\partial (q+\epsilon \psi)} \frac {d (q+\epsilon \psi)} {d \epsilon}) \right|_{\epsilon = 0} = \left.(\frac {\partial L(q+\epsilon \psi)} {\partial (q+\epsilon \psi)} \psi) \right|_{\epsilon = 0}##
And now, I don't know how to continue since I think it is not allowed to evaluate the arguments of the Operator ##\frac {\partial L(q+\epsilon \psi)} {\partial (q+\epsilon \psi)}## at ##\epsilon = 0##
In my opinion this evaluation has to be done after the derivation which I can't calculate since it's not clear how ##L## depends on ##(q+\epsilon \psi)##
As you write it, the Lagrangian is a function only of the one variable. You shouldn't be writing a partial derivative. But to answer your question the two functions ##L'(q+\epsilon\psi)## and ##L'(q)## agree at ##\epsilon=0## where ##L'(y)=\frac{dL(y)}{dy}##.
Can you think of a way to write ##L(q+\epsilon \psi)## in terms of derivatives of ##L## with respect to ##q##, given that ##\epsilon \psi## is very small?
Yes... look up Taylor-Maclaurian series expansion of a function in your Calculus 1 textbook.
  • · Replies 19 ·
  • · Replies 16 ·
