Derivative problem that I thought would be easy
  • Thread starter Thread starter Loopas
    Derivative
Loopas
I've attached a picture of the problem.
The problem asks from f'(0) of the function:
f(x)=e^(2x)*g(x)
g(0)=-5 and g'(0)=3 are given.
So the answer I came to was:
f'(x)=2e^(2x)*g'(x)
However, when I work out the numbers I get:
f'(0)=6
This is not right. So I figured I made a mistake a mistake when taking the derivative of f(x). Now I'm stuck because I'm not sure how to derive the function when g(x) isn't explicitly given.
f(x)=e^(2x)*g(x)
f'(x)=2e^(2x)*g'(x)
f'(0)=6
Yes, you made a mistake when taking the derivative of f(x). Use the product rule.
Likes 1 person
The product rule say that:
(f(x)g(x))'=f'(x)g(x)+f(x)g'(x)
You did:
(f(x)g(x))'=f'(x)g'(x)
Which is incorrect.
Likes 1 person
Wow, thanks guys. Sometimes sleep deprivation can do some crazy things.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
