Designing a High-Heat Flux Test Rig for Intel Processors
  • Thread starter Thread starter Cyrus
    Processor Test
The discussion focuses on a project for designing a high-heat flux test rig for Intel processors, emphasizing the need for advanced cooling technologies due to increasing power dissipation in electronics. Participants are tasked with creating a rig capable of removing heat fluxes up to 2000 W/cm2 from a 1 cm x 1 cm area, considering factors like temperature limits, measurement accuracy, and cost. Various liquid cooling methods, such as microchannel cooling and spray cooling, are suggested as potential solutions. The project is described as deceptively simple due to its open-ended nature, allowing for creativity in design. Collaboration in groups of up to three is encouraged, with a report submission deadline set for November 29th.
Cyrus
Every semester, at least one of my classes involves a project. For Mechanics of Materials, we made a beam, performed an analysis and tested in a universal bending machine. For Thermodynamics, we had to design a HVAC system that provided Heating/Air Conditioning, dehumidification, a cool water supply, and power using microturbines. For Fluids, we had to make a working model of a Urinary System and perform an analysis on the flowrates and use the non-dimensional correlations to scale the findings back down to a human size bladder. This semester, we had to make a test rig for an Intel Chip. Here is the project statement:
ENME 332: Heat Transfer Design Project Fall 2006
Future electronic systems and power electronics will require increasing use of high-heat flux removal technologies-see the attached NY Times article on the thermal problems facing electronics. High heat flux thermal designs are necessary to maintain lower operating temperatures, which increases the reliability of components and can result in higher performance. Use of liquid cooling will become unavoidable as the power dissipation levels increases in future electronic systems. Possible liquid cooling technologies include singlephase liquid cooling in microchannels, immersion flow boiling, spray cooling, jet impingement cooling, thermosyphons, and heat pipes. We wish to build a test rig to measure the heat removal capability of various cooling technologies such as sprays and jets. It is your job to design a heater that can remove heat fluxes up to 2000 W/cm2 from a 1 cm x 1 cm area. The fluid striking the surface is at a temperature of 20°C, and the heat transfer coefficients can be up to 400,000 W/m2-K. One design that has been used in the past to test much lower heat fluxes is shown on Figure 1. One or more cartridge heaters are placed into a block of copper, and the heat flux is determined from the temperature gradient in the region below the cooled surface measured using thermocouples spaced a known distance apart. Some aspects you should consider in your design are 1). temperature limits, 2).accuracy of your heat flux measurements and instrumentation, 3). Cost. Your design should use readily available parts (i.e., no materials like “unobtainium”). Please submit a report describing your design (5 pages max., single spaced, 1” margins, Times New Roman) including designs considered, dimensions, heat transfer performance, measurement accuracy, a list of materials, and cost. You may work in groups of up to three—you should choose your groupmates from your section. The project is due Wednesday, Nov. 29th in lecture.
The hardest part about this project was that it was completely open. Anything goes, so long as you can provide up to 2000W of power. As my professor said, it's deceptively simple at first sight.
I'm actually quite interested in this and the links don't work...
"File not found
The link you have clicked is not available.
Use only the link that was generated by YouSendIt and emailed to the recipient(s)."
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
