strive said:
This problem is somewhat similar to the problem of controlling the fuel line during mid-air refueling.
For a probe and droque system, the drag from the drogue (like a shuttlecock) keeps the end of the flexible line near horizontal. The receiving aircraft intercepts the line and attaches to it. For a flying boom, there are movable airfoils near the end of the boom and an operator on the sending aircraft has to control the boom.
strive said:
... sufficient roll stability could be achieved by a high wing back-sweep.
any passive geometry for roll stability will be affected by a cross wind component, causing the aircraft to lean away from the cross wind (roll downwind), just the opposite of what would be wanted.
strive said:
As the car will accelerate and the planes altitude increases, the downward force (due to the tether) will increase
Tension in the line will be proportional to the lift minus the weight of the aircraft (in the direction of tension). I'm not sure what the ideal location for the tow connector on the model should be. For a tow where the glider follows behind and slightly above the towing aircraft the tow hook is in the nose. For a hi-start type launch (similar to a kite being launched), the tow hook is in front of the center of lift, usually close to the center of mass.
strive said:
With 25 km/h you’ll be hard pressed to make anything fly ...
That's fast enough for a model aircraft with a light wing loading. To carry a load, it's probably going to need to be a larger model, with a wing span in the range of 2.5 to 3 meters.
strive said:
Before rc transmitters were widely available, people used to fly powered airplanes that had several tethers by which they were controlled much as kites are.
I'm not aware of such models. There were/are "U" control models, where the pilot controls the elevator on the model via a pair of lines that feed through guides on the innner wing. Sometimes there's a third line in the middle, usually for throttle control. The rudder is slightly offset so that the model yaws a bit outwards to keep the lines taught. The lines provide roll stability. There are also free flight models that are completely passive. For roll stability they use dihedral in the wings. For pitch stability, the center of weight is in front of the center of lift, and the "elevator" is trimmed so that the model flies level at a certain speed. For yaw stability, weathervane effect from the vertical tail surfaces are used, but the rudder is slightly offset since the goal is to have the model make large circles in the air. The models aren't always completely passive, as there's usually a timer device that sets the trim for the powered or launched climb, then when the timer expires, the trim is switched to glide mode. For the completely passive models, the motor is just strong enough to produce the speed needed for a climb and not too fast which would result in looping.
