Calculate Speed of Football at 5.0m Above Ground
  • Thread starter physical?eer
  • Tags
    Desperate
In summary: You also know the potential energy of the ball at this point, since it is 5 m above the ground. So you can find the new kinetic energy, by solving for the velocity. There is only one unknown here, the initial velocity of the ball. You can find that by using the equation Et1 = ek1 + eg1. Then, you can find the final velocity by using the equation Et2 = ek2 + eg2. Alright, so that's all for this summary.In summary, a .565kg football is kicked from the ground at a speed of 22 m/s. It has a velocity of 19.6468827 when it passes between the uprights
physical?eer
a .565kg football is kicked from the ground at a speed of 22 m/s. what is its speed just as it passes between the uprights 5.0 m above the ground?
please help!
G:
m= .565 kg
v= 22m/s
5.0 m
r:
velocity
a:no kinematics's equations
What about conservation of energy? What do you know about that?
the only formulas i have are these
Energy Total = Energy kenetic + Energy Gravity
Ek = 1/2 mv^2
Eg = mgh
P=E+W
W= mgh
OK, the first of those are useful here. What do you think you should do with them? What does conservation of energy mean?
conservation:
energy can't be made or destroyed
total energy of any closed system remains same
energy can change from one from to another but total energy is same
So if the ball is on the ground, what does that tell you about the gravitational potential energy? Can you find the kinetic energy the ball has right after it is kicked?
well
Et= ek + eg
i know my v1 i think is 22m/s or is that my v2?
my h is 5.0
umm and my mass is .565
if i understood the velocity part that would help i think
cuz ek = 1.2 mv^2 but
v is v2-v1 and v2 is either 0 or 22
and no gravitational energy
physical?eer said:
well
Et= ek + eg
my h is 5.0
Your initial velocity (v1) is 22 m/s
Think of it in two parts. The first part is when the ball in on the ground right after being kicked. The second is when the ball is at the 5 m height. Write out the energy terms for each part.
So for first part Et1 = ek1 + eg1
for the second Et2 = ek2 + eg2
For the first part, when the ball is at ground level, that is correct.
ET1 = 0
Et2 = 136.73 (1/2 * .565kg * 22m/s^2)
then...
wait hold on i think i missed it so at 5.0 m above ground its 22m/s right
Et1 is the sum of the two kinds of energy. When the ball is kicked, it has kinetic energy, and no potential energy since it is on the ground. So Et1 should be what you calculated for Et2.
Et2 will also be the sum of the kinetic and potential energies, but this time, the potential energy is NOT zero, since the ball is now 5 m above the ground. So you are given enough information to find the potential energy of the ball at this point, and you need to find the new kinetic energy.
NO. At 5 m above the ground, you don't know the velocity. That is what you are trying to find.
k i calculate Eg to be 27.685
then i looked at kinetic energy...but that leaves 2 variables velocity and kinetic energy in the formula
Ek = 1/2 mv^2
hmm...
You know that the initial kinetic energy of the ball must be equal to the sum of the kinetic and potential energy when the ball goes through the uprights. So you can find the final kinetic energy of the ball, since you know the potential energy. Once you have that, you can solve for the velocity. There is only one unknown here.
sorry i don't understand... how does Ek1 = Ek + Eg and even then i don't no Ek:confused:
Because energy must be conserved. If the ball ONLY has kinetic energy to begin with, that means when it is above the ground at 5 m, some of that initial kinetic energy goes into gravitational potential energy, and some remains as kinetic energy. You are trying to find the FINAL kinetic energy, it will be different that the initial kinetic energy. Once you find the final kinetic energy, you can then find the velocity the ball has at 5 m above the ground.
so therefore Ek2 =
et1-eg
Et1 = 136.73 (1/2 * .565kg * 22m/s^2)
so ek2 =109.045 (136.73-27.685)
and so there fore...
i got 19.6468827 as velocity
sounds good...is it?
physical?eer said:
so therefore Ek2 =
et1-eg
OK, so now you know the kinetic energy of the ball when it goes through the uprights. Now you can find the velocity, using the equation for kinetic energy (Ek = 0.5*m*v^2).
That looks reasonable. Don't forget to include your units in your answer.
was i wrong?
o i just saw your reply!
awesome
thank you soooo much!
physical?eer said:
was i wrong?
No, you just posted your answer before I saw it. I didn't realize you have calculated it already.
You're welcome. :smile:
1. How do you calculate the speed of a football at 5.0m above ground?
To calculate the speed of a football at 5.0m above ground, you will need to know the initial velocity, acceleration, and time. The formula for speed is speed = (initial velocity) + (acceleration x time). You can measure the initial velocity by using a speed gun or by calculating the distance the ball travels in a certain amount of time.
2. Why is it important to calculate the speed of a football at 5.0m above ground?
Calculating the speed of a football at 5.0m above ground can give us valuable information about the trajectory and velocity of the ball. This information can be used to improve player performance, understand the physics of the game, and make accurate predictions about the path of the ball.
3. What factors can affect the speed of a football at 5.0m above ground?
The speed of a football at 5.0m above ground can be affected by various factors such as air resistance, wind speed, surface friction, and the force applied by the player. These factors can impact the acceleration and trajectory of the ball, ultimately affecting its speed.
4. Can the speed of a football at 5.0m above ground be faster than the speed at ground level?
Yes, the speed of a football at 5.0m above ground can be faster than the speed at ground level. This is because the ball has more potential energy when it is released from a higher point, which can translate into a higher speed. Additionally, air resistance may be reduced at higher altitudes, allowing the ball to travel faster.
5. How can the speed of a football at 5.0m above ground be used in game analysis?
The speed of a football at 5.0m above ground can be used in game analysis to evaluate player performance, assess the effectiveness of different techniques and strategies, and make adjustments to improve the speed and accuracy of the ball. It can also be used to compare the performance of different players and teams.
  • General Math
