Detector of even numbers in logic circuit
The discussion revolves around designing a logic circuit that detects even numbers based on binary representations of signed integers. Participants explore the characteristics of binary numbers that indicate evenness, specifically focusing on the least significant bit of the inputs.
  • Homework-related
  • One participant seeks guidance on deriving the equation for detecting even numbers from two binary inputs, A and B.
  • Several participants note that the least significant bit of a binary number determines its parity, with 0 indicating even and 1 indicating odd.
  • There is a suggestion to use Karnaugh maps for simplifying the logic equations for inputs A and B.
  • Participants discuss how to combine conditions for both inputs A and B to determine the output F.
  • One participant proposes the equation F = /B0 * /A0, indicating that both least significant bits must be 0 for F to be 1.
  • Another participant questions the validity of the proposed equation when both inputs are odd.
  • There is a discussion about propagation delays in the circuit components and how to calculate the maximum period required for the output to stabilize.
Participants generally agree on the role of the least significant bit in determining evenness, but there is some confusion regarding the combination of conditions and the correctness of the proposed logic equation. The discussion about propagation delays also shows varying perspectives on how to approach the calculation.
Some participants express uncertainty about how to represent multi-bit binary numbers in the circuit design, and there are unresolved questions about combining conditions into a single logical statement.
This discussion may be useful for students and practitioners in electrical engineering or computer science, particularly those interested in digital logic design and circuit analysis.
Max0007
I need to make a circuit that detects even numbers.
Need to find the equation for F when input A and B are both even.
Input A: Word of 5 -bit signed representation in complement 2.
Input B: Word of 3 -bit signed representation in complement 2.
for B:
000 = 0 (even)
001 = 1
010 = 2 (even)
011 = 3
100 = -4 (even)
101 = -3
110 = -2 (even)
111 = -1
For A:
same as B but with 5 bits.
00000 = 0 (even)
00001 = 1
00010 = 2 (even)
00011 = 3
00100 = 4 (even)
00101 = 5
00110 = 6 (even)
00111 = 7
11111 = -1
I am just wanting to know the steps on how I start this.
Do I do Karnaugh for both inputs then join both equation together?
What feature of a number represented in binary (either unsigned or 2's complement) allows you to tell that it is odd or even? Don't need to convert it to decimal... There is something all even binary numbers have in common that allows you identify them as even.
I realized that binary ending with a 0 = even and binary ending with 1 = odd.
So basically its F = /A/B ??
You are not interested in all of the binary digits of A or B. Just the least significant binary digit.
How do I make my logic circuit to check only the least significant binary digit?
if input B least significant bit = 0 then its an even number.
if input A least significant bit = 0 then its an even number.
If A and B = 0 then its an even number and F = 1
but how do I actually write this in an equation with gates?
Why do you have "If A and B = 0 then its an even number and F = 1" as a separate condition?
Why do you have the first two statements as independent statements? They are NOT true taken as stand-alone statements.
How do you combine all 3 statements into one statement?
Sorry my english is not my primary language I did not meant to split it up in 2 condition, just that when A and B = 0 then the output is 1.
Here are my Kmap for input A and B.
You had it right in your statements and now you are complicating it. Why?
Maybe this is the root of the problem. When you have to draw an actual circuit, how will you represent a 5-bit binary number? A 3-bit binary number? What will you draw?
I don't know, but here the final equation:
F = /B0 * /A0
That looks right.
lewando said:
That looks right.
Really? How about when both numbers are odd?
if both numbers are odd it would output 0 since I am only checking the least significant bit. and the least significant bit in odd numbers will be 1. and 1 * 1 would output 0 since there are NOT gates in both inputs or am I wrong ?
Sorry, I got to thinking we were doing an adder output. You and lewando are both right and I'm wrong. Now *I* was over thinking it :smile:
No worries man, you helped me a lot today and these past days, I really appreciate it man. I just wish my teachers were a little bit better :(
one last thing :)
If an inverter has a 2 ns propagation delay , an AND logic gate has a 5 ns propagation delay and an OR gate has a 4ns delay , what is the maximum period required by the circuit in order to update the output F ?
would I just do 2ns x 2 sicne I have 2 inverter and 5ns x1 since I only have one then add up everything ? = 4+5=9ns ?
From a time-flow perspective, the inverters are operating in parallel of each other and the AND gate is in series with the inverters. You are correct to not consider a nonexistant OR gate. 9 ns would be incorrect. Rethink.
2+5= 7 then
I
Looks right!
lewando said:
Looks right!
how would I calculate it if I had 3 different gates in parallels?
The worst-case delay (longest) is dominant.
Nice awesome thanks.
I really learn a lot more here than in Class at the University so far.
University for undergrad is often overly-difficult by design. You are wise to seek additional resources to complete your understanding. Keep up the good work!
10K
  • · Replies 26 ·
  • · Replies 26 ·
