Determinat of a continous matrix?
  • Thread starter Thread starter wenty
    Matrix
wenty
Determinat of a "continous" matrix?
a(x,y) is a matrix element ,and x,y is the row and column index.
If x,y are real numbers, how to calculate the determinat of this matrix or the inverse matrix?
An example of this kind of matrix is <k|H|k'>,a Hamiltonian in momentum representation.
So it's an infinite dimensional matrix...
If the matrix elements \hat{H}_{k,k&#039;}=:\langle k|\hat{H}|k&#039; \rangle are real,then this matrix is symmetric.Then u can find an orthogonal matrix which would diagonalize the hamiltonian matrix.
Then
\det\left(\hat{H}_{k,k&#039;}}\right)=exp \ \left(trace \ ln \hat{H}^{diag}_{k,k&#039;}\right)
Daniel.
Then
Daniel.
The problem is how to find this orthogonal matrix.In ordinary case,to find this matrix we should solve an equation which needs to know the determinant of the given matrix.Then the question remains.
How about u search for a basis (a new set of kets |k\rangle) made up of eigen vectors (in general sense,the spectrum in continuous) of the Hamiltonian,and then everything would be tremendously simple...?
Daniel.
Daniel.
But if what you only know is a(i,j),which isn's the matrix elements of the Hamiltonian,how do you find the eigen vectors?
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
