Determine Inside Diameter of Horizontal Pipe Constriction
To determine the inside diameter of the constriction in a horizontal pipe with a known flow rate, Bernoulli's equation is relevant but requires careful application. The pressure at different heights in the pipe affects fluid dynamics, as the fluid's velocity changes with varying cross-sectional areas. The volume flow rate must remain constant throughout the pipe, meaning that the product of the cross-sectional area and velocity is equal at both sections. Understanding that the fluid's velocity is not constant and that pressure is influenced by depth is crucial for solving the problem. Clarifying these concepts will aid in grasping the relationship between flow rate, area, and pressure in fluid mechanics.
zetabug
The inside diameters of the larger portions of the horizontal pipe in Figure P9.40 are 2.80 cm. Water flows to the right at a rate of 2.00 10-4 m3/s. Determine the inside diameter of the constriction. Answer in (cm)
Here is the picture http://www.webassign.net/sf5/p9_40.gif"
Could you guys please show me how to do this? Not just the answer I want to be able to grasp the concept. Thanks
I'd Assume
1/2pv^2 + pgy = 1/2 pv^2 + pgy
Has something to do with it, but I don't really know where to start.
Honestly I have no idea where to start. How does the info given relate to anything?
From the above equation I can get
1/2(1000)(2e-4)^2 + 1000 *9.8*.1?= 1/2 1000 (2e-4)^2? + 1000 *9.8* .25?
But this doesn't use a lot of the info. Any help would be appreciated.
That equation is Bernoulli's equation, but you are missing a term for pressure. (Look it up!) Hint: The heights of the fluid in those vertical segments will tell you the pressure in the fluid at those points.
Read this: http://hyperphysics.phy-astr.gsu.edu/hbase/pber.html"
How exactly does the heights give me the pressure? I though pressure=F/Area?
And also is the velocity constant for the entire pipe?
Realize that the fluid in the vertical sections is not moving--so pressure just depends on depth.
That's still true.
If the velocity were constant throughout the pipe, you'd have some explaining to do. That would mean that more fluid flowed through the wide section of pipe per second than flowed through the narrow section--but that can't happen, right? (The amount of fluid flowing per second must be the same everywhere--otherwise where is the water going?) Hint: The volume flow rate is given by area*speed.
The book claims the answer is that all the magnitudes are the same because "the gravitational force on the penguin is the same". I'm having trouble understanding this. I thought the buoyant force was equal to the weight of the fluid displaced. Weight depends on mass which depends on density. Therefore, due to the differing densities the buoyant force will be different in each case? Is this incorrect?
17K
16K
