Determine the length the pendulum has travelled
  • Thread starter Thread starter Nusc
    Length Pendulum
To determine the length a pendulum has traveled with an amplitude of 10.0 m and 7 vibrations, one must first understand the relationship between amplitude, frequency, and the total distance traveled. The total distance can be calculated by considering that the pendulum travels a distance equal to twice the amplitude for each complete vibration. Therefore, for 7 vibrations, the total distance would be 7 vibrations multiplied by 2 times the amplitude. Assumptions may include treating the pendulum's motion as simple harmonic motion and neglecting factors like air resistance. The final calculation yields a total distance traveled of 140.0 m.
Nusc
A pendulum has an amplitude of 10.0 m and undergoes 7 vibrations.
Determine the length the pendulum has travelled, how do we do this if we don't know the frequency? What assumptions are we ought to make?
you need to show some work first. Look at your equations and see what parts you do have and how you can replace the missing parts with relationships
Think: what is amplitude?
ehild
