How Can You Identify the North Pole of a Bar Magnet Without Another Magnet?
  • Thread starter Thread starter pivoxa15
    North pole Pole
To identify the north pole of a bar magnet without using another magnet, one suggested method is to suspend the magnet using a string and allow it to rotate freely. However, this approach does not definitively indicate which end is north or south without a reference. Another idea involves using a current-carrying wire to create an electromagnetic field, but this still does not clarify the magnet's poles without prior knowledge. Some participants proposed using the night sky for orientation, but this also requires prior knowledge of the magnet's orientation. Ultimately, the challenge remains in determining the poles without any magnetic reference, leading to confusion about the constraints of the problem.
pivoxa15
Explain how you would determine which was the north pole of a bar magnet, without using any other magnet.
none
If it's small enough you might be able to make it into a compass like object but if its heavy than the magnetic field of the Earth is not strong enough to deflect it. So this might not be 100% correct answer. The answer should encompass all sizes of magnets.
Is it allowed to use current carrying wires?
I think the best way is to use a string/thread and tie it at the middle of the bar magnet. Then just hang it out by holding the string/thread and let it move by itself without applying any force from you hand/fingers as much as possible.
if that doesn't work, are you allowed to magnetize something much smaller and lighter with the original magnet?
As long as that something is not another magnet. But you still couldn't tell which was the north and south pole because if it was steel and you lined the south pole with it, the steel will induce a north side facing the magnet. And vice versa.
But you still woudn't know which was the N and S pole without another compass , which is a magnet hence disallowed.
I think so since the question only said you can't use another magnet. So you are suggesting loop a wire with current around a magnet and notice the direction of the current. This should induce a magnetic field along with the intrinsic magnetic field in the electromagnet (with a magnet core). If the resultant magnetic effect is greater than the place where the current is traveling towards is the N pole and vice versa.
Now i know which way north is w/o a compass--are you sure the problem is this constrained? If nothing else you could use the night sky.
I said that another compass was needed because you actually don't know which is N and S on the original magnet (the S will point towards the S and N towards the N but you don't know which is which), which you have made it into some sort of a compass if folllowing Ruben's advice. So you suggest using to the night sky as a guide but you still would need to know which was N and S before hand or find the information in a book. But the original people who found out had to use a proper compass hence another magnet. In this way I think the way suggeted by P3X-018 and elaborated by myself is a better answer to the question. The question clearly stated that another magnet cannot be used.
I guess I'm properly confused, owing much to my igorance, no doubt. My thinking was as follows, A big bar magnet suspended on however frictionless a bearing will be under the most minute torque. I have no idea,but guessing it could hang for days or weeks, months centuries even, So assuming its a compass its in its own right, we need to either make a Focault like pendulum and wit saa long time or diminish the inertia-thatis sympathetically magnetize a needle, paying attention to orientation, and stick the now low mass N/S indicator into a cork, whatever,
Basically build a scale mod of the bigem, If it points toward Polaris, bingo
