Determine the total current in the attached diagram
  • Thread starter Thread starter DevonZA
    Current Diagram
The discussion focuses on calculating the total current in a circuit diagram. Initially, the user calculated the total resistance incorrectly by misidentifying the arrangement of resistors. After clarification, it was determined that there are three resistors in parallel, leading to a revised total resistance calculation. The correct total resistance was found to be 6.42 ohms, resulting in a total current of 4.67A when using the formula I=V/R. The final calculations confirmed the accurate total current based on the corrected resistor configuration.
DevonZA
Hope this is posted in the right place:
R parallel = 1/9.7 + 1/43 = 0.366^-1 = 2.98ohms
R series = 4.3 + 7.4 = 11.7ohms
R total = 2.98+11.7=14.68ohms
I=V/R
= 30/14.68
= 2.04A
The answer given is 4.67A, what am I doing wrong?
Thanks,
Devon
Where does 7.4 come from and what is in series here?
If you use a number not given in the problem statement, please explain where it comes from.
There are more things in parallel.
My apologies the 7.4 ohms should be where the second 4.3ohms in series is on the attached sketch. I drew that up late last night.
Hint: There are actually three resistors in parallel.
Likes DevonZA
I see only 2?
Aha thank you CWatters I see that the 7.4ohm resistor is in fact in parallel.
Itotal=Vtotal/Rtotal
Rparallel = 1/9.7 + 1/4.3 + 1/7.4 = 2.12ohms
Rseries = 4.3ohms
Rt = 2.12 + 4.3 = 6.42ohms
It=Vt/Rt
It = 30/6.42
It = 4.67A
Looks right to me.
Likes DevonZA
