Determine Velocity at each second
  • Thread starter Thread starter CollegeStudent
    Velocity
A ball thrown straight up at 30 m/s experiences constant acceleration due to gravity, which is -10 m/s². The time to reach the peak is calculated as 3 seconds, resulting in a total flight time of 6 seconds. The maximum height achieved is 90 meters. To find velocity, displacement, and acceleration at each second, the formula Vf = Vi + at can be used, with attention to the sign of acceleration depending on the chosen direction. The discussion emphasizes that the sign convention for velocity and acceleration must be consistent to accurately determine their values throughout the motion.
CollegeStudent
A ball is thrown straight up at 30m/s. Assume g is 10m/s/s Show the dispacement, velocity, and acceleration at each position.
Vf² = Vi² + 2aΔx
Vf = Vi + at
So first I wanted to solve for the time it takes to go up so
Vf = Vi + at
0 = 30 + (-10)t
t = -30/-10 = 3 seconds up
then just times 2 because its the same coming down
so 6 seconds in all
Now for distance up
Vf² = Vi² + 2aΔx
Δx = (Vf² - Vi²)/2a
Δx = (0 - 900)/2(-10)
Δx = (-900)/(-20)
Δx = 45m up
and again times 2
so 90 meters in all
Now for some reason I'm having trouble figuring out how to find the velocity,displacement,and acceleration at each 1 second interval.
Should acceleration stay the same until the top where its 0 then change to +10m/s/s?
And how and what formula would I use for the other two?
Thanks in advance everyone
Hint: For the velocity simply tabulate Vf = Vi + a*t. On the way up, a is negative. Use results for Vf in your first equation and solve for delta X. Repeat.
Thanks Lawrence ...I kept thinking I had to bring in another formula. Thanks again!
Actually ...when solving for acceleration ...I get that on the way up its negative ...but by using something using my results from above...
Vf = Vi + at
(Vf-Vi)/t
Using say
V(0)=30m/s and V(1)=20m/s
So
(20-30)/1 = -10 which I assumed
But
Using V(4) and V(5)
(-20 - (-10))/1
That comes to -10 as well...but shouldn't acceleration be positive at this time?
If you choose the starting point to be the velocity at the highest point where it is zero and let downward velocities be positive, then you will get a positive acceleration.
The equation Vf = Vi + at enables one to determine a velocity at a later time under constant acceleration over that time period. If the acceleration is in the same direction as the velocity and velocity is positive, acceleration is positive. Vice versa is also true. If you use it to determine accelerations, the sign of the acceleration is dependent on the sign convention you choose for the velocities. If the magnitude of the velocity increases, the acceleration has the same sign as the velocity. If magnitude of velocity decreases, acceleration has the opposite sign.
