Understanding the Detonator Paradox: A Relativity-Based Explanation
  • Thread starter Thread starter fizzzzzzzzzzzy
    Paradox
fizzzzzzzzzzzy
theres this problem in my book that talks about the detonator paradox, where there's one U shaped figure and one T shaped figure and there's a button for a bomb at the bottom of the U shaped figure, and the question is if the 2 figures go toward each other so that they fit, will there be a detonation. well the standard answer to this is that it will detonate because in the refrence frame where the bomb does not detonate, the end of the T will continue moving and hit the button since forces only move at the speed of light, so the bomb will detonate.
However i looked at the other refrence frame and noticed that in the RF of the U structure, the legs of the U will collide with the legs of the T before the button is pressed while in the RF of the T, the legs of the T collide with the legs of the U after the button is pressed. could someone explain this for me?
Since the two events--(1) bottom of T hitting the button and (2) top of T hitting U structure--are not causally linked* there's no problem in different frames seeing them occur in different order. (The relativity of simultaneity at work.)
*By that I mean that one event is not the "cause" of the other.
You haven't explained the problem very well. Also, you've misrepresented the solution (there is no "refrance from where the bomb does not detonate").
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
