How can the rotary power of a molecule be determined by comparing substructures?
  • Thread starter Thread starter louie3006
Determining whether a molecule is dextrorotatory or levorotatory cannot be done solely by examining its 3D structure; it requires experimental methods. The key technique involves passing plane-polarized light through the compound. If the light is rotated clockwise, the compound is classified as dextrorotatory; if it rotates anti-clockwise, it is levorotatory. There is ongoing research in this area, including studies that compare the rotary power of substructures within larger molecules to predict the overall behavior. Relevant literature, such as an article from the Journal of Organic Chemistry, may provide further insights into these methodologies.
louie3006
how can i tell if a molecule is dextorotory or levorotory by looking at the 3-d presentation? any thoughts!
Chemistry news on Phys.org
No, we can not judge this just looking at the 3-d presentation of a compound.
It is judged by experimentation.
We pass plane-polarized light through the compound..
if the compound rotates the light clockwise, it is said to be dextro-rotatory..
and if the compound rotates the light anti-clockwise, it is said to be levo-rotatory.
There is some work in that field. I remember something about the requirement to compare a part or sub structure's rotary power of a larger molecule and apply the result across the entire molecule. References within http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6THT-4CPD575-3&_user=10&_rdoc=1&_fmt=&_orig=search&_sort=d&_docanchor=&view=c&_searchStrId=1066511998&_rerunOrigin=google&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=7b2dce750534a20105a5a375820dfe5c" (specifically, J. Org. Chem. 2003, 68, 5186) should describe one group's efforts along those lines. If you are close to a library, you might look it up.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
