How Do You Calculate the Tension in Cables Suspending a Loudspeaker?
  • Thread starter Thread starter circuscircus
    Tension
To calculate the tension in the cables suspending a 20kg loudspeaker, first determine the weight of the loudspeaker, which is 196N (w = mg). The cables form equal angles with the ceiling, leading to the conclusion that the tension in both cables is identical. By analyzing the forces and breaking them into components, the correct tension can be derived. The calculated tension is 147N, which differs from the initial weight due to the angle of the cables. Properly drawing a free body diagram (FBD) helps clarify the forces at play.
circuscircus
A 20kg loudspeaker is suspended 2 m below the ceiling by two 3m long cables that angle outward at equal angles. What is the tension in the cables?
cos theta = 2/3, theta=48.2 degrees
w=mg=20kg * 9.8m/s^2 = 196N
But the answer is 147N
Try drawing a FBD and see what the forces tell you.
You have to break this problem down into components in order to solve it.
Hint: Since the angles are the same, the tension in both cables will be the same.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
