Differential Eqn: Find an expression of the velocity of a rock.
coolusername
A 20 kg rock falls with the force of gravity acting on it. Another force acts on the rock (same direction as gravity) that is proportional to the velocity squared, 100v^2. Come up with an expression of the rock's velocity at any time t.
Hint: (d/dx)(tan^-1(x)) = 1/(1 + x^2)
F(net) = ma = Fg + 100v^2
ma = mg + 100v^2
a = g +(100v^2)/m (m=20)
dv/dt = g + 5v^2
dv/dt = g((5/g)v^2 + 1)
dv/((5/g)v^2 + 1) = g(dt)
dv/((root(5/g)*v)^2 +1) = g(dt) (integrate both sides)
tan^-1(root(5/g)*v) = gt + C
root(5/g)*v = tan(gt + C)
v(t) = (root(g/5))tan(gt + C)
I want to know if I can get rid of the constant as well as if my approach to the general solution is correct. Also if my general soln is correct.
Thanks!
You cannot ignore units like that. 20 and 20kg are completely different things.
The force given as 100v^2 has mismatching units, are you sure there is nothing else given there?
You cannot get rid of the constant as you do not know the initial velocity.
That's all that the question gives. There's no initial conditions given either. I assumed that the additional force would equal 100v^2 as it says it's proportional. But you're right, the units don't match up.. Could it be possible that the units are hidden within the coefficient of v^2?
Yes, there has to be a dimensional coefficient with the proper units.
Normally the force proportional to v2 would be something like the drag force, which acts in the direction opposite to the velocity, hence against gravity in the example. But oh well.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
