Solving a Nonlinear Differential Equation: y'' + (y')^2 = 1
In summary, the conversation was about solving the equation y \frac{d^2y}{dt^2} + (\frac{dy}{dt})^2 = 1 using various methods such as the integrating factor method and separation of variables. The final solution involved two arbitrary constants and the final equation was y = \sqrt{t^2 + Ct} .
Ed Aboud
201
Solve
[tex] y \frac{d^2y}{dt^2} + (\frac{dy}{dt})^2 = 1 [/tex]
[tex] \frac{dy}{dt} = v[/tex]
[tex] \frac{d^2y}{dt^2} = v \frac{dv}{dy}[/tex]
[tex] yv \frac{dv}{dy} + v^2 =1 [/tex]
[tex] \frac{dv}{dy} + \frac{v}{y} = \frac{1}{vy} [/tex]
[tex] I(y) = exp ( \int \frac{1}{y} dy)[/tex]
[tex] I(y) = y [/tex]
[tex] y \frac{dv}{dy} + v = \frac{1}{v}[/tex]
[tex] \frac{d}{dy} (vy) = \frac{1}{v}[/tex]
[tex] y= \frac{ln(v)}{v} + \frac{C}{v} [/tex]
Thanks.
Hi Ed,
This is where the error shows up: you are integrating one side with respect to y and the other with respect to v. Notice that your fourth line
is not of the form you would normally apply the integrating factor method you have used: the right-hand side should be a function of y only.
All is not lost, however. From your third line
you can instead use the method of separation of variables.
You are also taking rather of the long way around. The problem is much easier if you notice that your equation is
[tex]
\frac{d^2 (y^2/2)}{dt^2} = 1
[/tex]
Ok so here's my new attempt :
[tex] y v \frac{dv}{dy} + v^2 = 1[/tex]
[tex] y \frac{dv}{dy} + v = \frac{1}{v} [/tex]
[tex] y \frac{dv}{dy} = \frac{1 - v^2}{v} [/tex]
[tex] \int \frac{v}{1 - v^2} dv = \int \frac{1}{y} dy [/tex]
[tex] ln ( \frac{1}{ \sqrt{1 - v^2} }) = ln (y) + C [/tex]
[tex] y = exp(ln(\frac{1}{\sqrt{1 - v^2}}) + C ) [/tex]
[tex] y = \frac{1}{\sqrt{1 - v^2}} . e^C [/tex]
[tex] y \sqrt{1 - v^2} = e^C [/tex]
I don't think I am getting anywhere with it.
Thanks for the help.
Sorry I'm not sure where you got
[tex]
[/tex]
from.
[tex]
[/tex]
from.
I differentiated y^2/2 twice with respect to t. (y^2/2)'=y*y'. (y*y')'=y*y''+(y')^2. Your equation is y*y''+(y')^2=1.
I see it now, thanks very much for your help!
Sorry for double-posting but now I'm having doubts if I'm doing the next integral right.
[tex] \frac{d^2}{dt^2} (\frac{1}{2} y^2) = 1[/tex]
[tex] \alpha = \frac{1}{2} y^2[/tex]
[tex] \frac{d \alpha}{dt} = v[/tex]
[tex] \frac{dv}{dt} = 1[/tex]
[tex] v = t + C [/tex]
[tex] \frac{d \alpha}{dt} = t + C[/tex]
[tex] \alpha = \frac{1}{2} t^2 + Ct[/tex]
[tex] y^2 = t^2 + Ct [/tex]
[tex] y = \sqrt{t^2 + Ct} [/tex]
Correct?
Just integrate the first equation twice. The first time you get d(y^2/2)/dt=t+C. The second time you get y^2/2=t^2/2+Ct+D. So y^2=t^2+Ct+D. (I didn't multiply C and D by 2 since they are just constants anyway). So your answer is right. But you should have picked up another constant when you integrated dalpha/dt.
[tex] y v \frac{dv}{dy} + v^2 = 1[/tex][tex] y \frac{dv}{dy} + v = \frac{1}{v} [/tex][tex] y \frac{dv}{dy} = \frac{1 - v^2}{v} [/tex][tex] \int \frac{v}{1 - v^2} dv = \int \frac{1}{y} dy [/tex]
This wasn't wrong (although technically the C is -C). You can solve your last equation for v, which is dy/dt, and then separate variables again to finish the job (taking care to remember there are two square roots). Just a general note (Dick will go down the other track with you), you should expect two arbitrary constants in your solution.
Cool, got it now.
Thanks again!
1. What is a differential equation?
A differential equation is a mathematical equation that describes the relationship between a function and its derivatives. It is used to model many phenomena in various fields such as physics, chemistry, and engineering.
2. What is the difference between an ordinary and a partial differential equation?
An ordinary differential equation involves only one independent variable, while a partial differential equation involves two or more independent variables. This means that an ordinary differential equation has one derivative, while a partial differential equation has multiple derivatives.
3. How are differential equations solved?
Differential equations can be solved analytically or numerically. Analytical solutions involve finding an explicit formula for the function that satisfies the equation, while numerical solutions use computational methods to approximate the solution.
4. Why are differential equations important?
Differential equations are important because they provide a powerful tool for modeling and understanding real-world processes. They are used in many fields, including physics, engineering, economics, and biology.
5. What are some common applications of differential equations?
Differential equations are used to model a variety of phenomena, including population growth, chemical reactions, heat transfer, and electrical circuits. They are also used in fields such as finance, epidemiology, and ecology to study complex systems and make predictions.
