Differential equation second order;]
player1_1_1
I have differential equation;] this is equation from central force thing in Lagrange mechanics, you know, you know, its second order hahaha:D
y^3y^{\prime\prime}=ay+b
I will using method of making a first degree of this equation
I have
\frac{\mbox{d}y}{\mbox{d}x}=u(y)
\frac{\mbox{d}^2y}{\mbox{d}x^2}=\frac{\mbox{d}u}{\mbox{d}x}=\frac{\mbox{d}u}{\mbox{d}y}\frac{\mbox{d}y}{\mbox{d}x}=u\frac{\mbox{d}u}{\mbox{d}y}
and now I enter this new equation to before:
uy^3\frac{\mbox{d}u}{\mbox{d}y}=ay+b
u\frac{\mbox{d}u}{\mbox{d}y}=\frac{ay+b}{y^3}
u^2=-2\frac{a}{y}-4\frac{b}{y^2}+C
u=\frac{\sqrt{Cy^2-2ay-4b}}{y}
\frac{y}{\sqrt{Cy^2-2ay-4b}}\frac{\mbox{d}y}{\mbox{d}x}=1
someone who is good in mathematic, please tell me if this calculations was good and what can I do now, I was thinking about do this with area functions, but not sure, please tell me simplest way to solve it;] thank you!
I have
What is that -4 in u^2=-2\frac{a}{y}-4\frac{b}{y^2}+C? It must be -1 since if you take the derivative of the second term wrt y, a 2y would appear in the numerator which cancels out a factor 1/2 coming from another side so the term b/y^3 is then retrieved. Now that dx should be brought to the other side of equation and then there you are left with a simple integration. Just note that since you are taking the root of u^2=-2\frac{a}{y}-4\frac{b}{y^2}+C, don't forget to have a sign \pm accompanied with the radical.
AB
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
