Differential Equation stability at critical point
JJBladester
This is the autonomous differential equation: x" - 2x' + 37x = 0
Solve the above DEQ and state whether the critical point (0,0) is stable, unstable, or semi-stable.
Solution to the above DEQ is x = c1excos6x + c2exsin6x
I worked out the solution using the quadratic formula and got roots 1\pm6i. This gives you an \alpha of 1 and a \beta of 6, which yields the equation I put in part 2 above.
From there, I read that when you get a general solution in the form x = e\alphat(c1cos\betat + c2sin\betat) with \alpha < 0 and \beta \neq0, then you have a spiral point.
My problem is I'm not sure how to classify the stability of the critical point (0,0).
It's easy. Your characteristic roots have positive real part so (0, 0) is an unstable critical point. You can see why from your general solution. (0,0) (in the phase plane) is a critical point because x(t)= 0 for all t (so that x'(t)= 0 also) is itself a solution. It is an unstable critical point because if x is just slightly different from 0, that exponential means it gets larger and larger, moving rapidly away from (0,0).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
