Exact Differential Equations for Level Curves of u(x,y) = cos(x^2-y^2)
In summary, the differential equation du = 0 is a cosine function with two roots (x=-2 and x=2). The level curves u(x,y) = constant are the solutions to this equation.
Mark Brewer
38
Given u(x.y), find the exact differential equation du = 0. What sort of curves are the solution curves u(x,y) = constant? (These are called the level curves of u).
u = cos(x2 - y2)
partial derivative du/dx = (-2x)sin(x2 - y2)dx
partial derivative du/dy = (2y)sin (x2 - y2)dy
P = (-2x)sin(x2 - y2)dx ; Q = (2y)sin (x2 - y2)dy
I found that they're not exact differential equations
so, I'm using integration factors.
1/Q(P dx - Q dy) = R(x)
(1/(2y)sin (x2 - y2))((-2x)sin(x2 - y2) - (2y)sin (x2 - y2)) = R(x)
I get, R(x) = -x/y
Then,
F = exp^(R(x))dx
I get, F = exp^((-x^2)/(2y))
Then,
M = FP and N = FQ
so,
M = (exp^((-x^2)/(2y)))((-2x)sin(x2 - y2))
and
N = (exp^((-x^2)/(2y)))((2y)sin (x2 - y2))
I then took the partial derivative of M in respect to y, and this is where I am getting stuck.
I also have to take the partial derivative of N in respect to x.
Any help would be much appreciated.
At constant u,
$$du=\frac{\partial u}{\partial x}dx+\frac{\partial u}{\partial y}dy=0$$
What does this tell you about dy/dx?
Chet
Chestermiller said:
At constant u,
Chet
I believe it tells me that the partial derivatives are continuous
it may also tell me that the partials in respect to x and y are equal to u and 0...?
Checking for exactness,
P = (-2x)sin(x2 - y2)dx, Q = (2y)sin (x2 - y2)dy
dP/dy = (4xy)cos(x^2- y^2)
dQ/dx = (4xy)cos(x^2 - y^2)
dP/dy = dQ/dx, they are exact!
So, don't use the "integration factors", just find the general solution.
1. What are differential equation curves?
Differential equation curves are mathematical functions that describe the relationship between a variable and its derivatives. They are commonly used to model real-world phenomena in fields such as physics, engineering, and biology.
2. How are differential equation curves different from regular curves?
Differential equation curves are different from regular curves because they are defined by a differential equation, which relates the rate of change of the curve to its current value. This allows for more complex and dynamic behavior to be captured in the curve.
3. What are some real-world applications of differential equation curves?
Differential equation curves have many real-world applications, such as modeling population growth, predicting the spread of diseases, and analyzing the behavior of electrical circuits. They are also used in fields like economics and finance to model complex systems.
4. How are differential equation curves solved?
There are various methods for solving differential equation curves, depending on the complexity and type of the equation. Some common techniques include separation of variables, substitution, and using a numerical approach like Euler's method. Advanced methods such as Laplace transforms and power series expansions are also used for more complex equations.
5. What is the significance of differential equation curves in science?
Differential equation curves play a crucial role in science as they allow us to mathematically model and understand complex systems and phenomena. They are used in a wide range of fields, from physics and chemistry to biology and economics, to make predictions and inform decision-making. Additionally, they provide a powerful tool for analyzing and solving problems that would be difficult or impossible to solve with traditional methods.
