Differential equatn involving cos^2 and sin^2 in denominator
  • Thread starter Thread starter DryRun
    Differential
DryRun
(9cos^2(x) + 4sin^2 (x)).dy/dx = 6
The attempt at a solution
Rearranging:
(1/6).dy = 1/(9cos^2(x) + 4sin^2 (x))
(1/6).dy = 1/((3cos(x))^2 + (2sin(x))^2)
L.H.S becomes y/6 after integrating.
The R.H.S. (denominator):
I take out cos^2(x)
This leaves me with:
(9 + 4tan^2(x))
Then i use the standard integral formula for arctan
And i get: (1/3)arctan (2tanx/3)
Then I'm stuck...
What are you trying to find?
It's almost perfect. The LHS is y/6 + C. The RHS is 1/6 tan^(-1)((2 tan(x))/3).
What's y(x) then ?
Solving the ODE to get y in terms of x.dextercioby, for the R.H.S, after i worked it out, i get 1/2 tan^(-1)((2 tan(x))/3)
I used substitution t=tanx to integrate R.H.S.
Based on the formula: integral of 1/(a^2 + x^2) is 1/a tan^(-1)(x/a) + C
So, i don't understand how you got 1/6 instead of 1/2
I got the 1/2 by: 1/3 x 3/2 (obtained by dividing by the differentiation of 2t/3)
Any help?
Hmm...
... = \frac{1}{9}\int \frac{dx}{\left(\frac{2}{3}\sin x\right)^2 + \cos^2 x} = ...= \frac{3}{18} \int \frac{dp}{p^2 +1} = ...
Fill in the blanks.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
