Differentiation and integration
davon806
Hi,I saw a statement in my physics notes like this(Anyway it is a maths problem):
where L is a general differential operator.G is a green's function(I guess it is irrelevant)
My question is related to the red line:
Suppose we have this:
∂/∂x ∫ f(x-y)g(y) ∂y
is it generally true that
∂/∂x ∫ f(x-y)g(y) ∂y = ∫ ∂/∂x [ f(x-y)g(y) ] ∂y ?
Please answer it as simply as you can...Since I have not done multivariable calculus...(Though I would be happy to check it out if there is a theorem related to this.)
If the above is simplified to ∂/∂x ∫ f(x)g(y) ∂y ,then ∂/∂x [f(x) ∫ g(y) ∂y]
⇒ ∫ ∂/∂x [ f(x) ] g(y) ∂y
⇒ ∫ ∂/∂x [ f(x)g(y) ] ∂y
But I don't know what to do with the (x-y) term..
Thanks
The general formula is:
But you don't need this. You only need to use the properties of Dirac delta, i.e. ## \int \delta(x-y) f(y) dy=f(x)##.
Thanks :) Is there a name for this formula?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
